VFD error has no impact on program run
15 Feb 2021 18:47 #198957
by looping
VFD error has no impact on program run was created by looping
Hello
I have a HY620 with vfdmod that was running flawless. I recently added a braking resistor and now I have quite often Err4 when braking.
I didn't troubleshoot this yet but this point out another issue : The error is correctly display in my custom panel but this has not impact in LinuxCnc.
If I don't notice the error on a tool change for example and proceed, the spindle won't start and I will crash.
I select "Stop" on the VFD to clear the error.
How can I link this VFD error to for example the E-Stop signal ?
15 Feb 2021 21:45 #198989
by aleksamc
Replied by aleksamc on topic VFD error has no impact on program run
You can use HAL component
estop_latch
16 Feb 2021 17:19 #199089
by looping
Replied by looping on topic VFD error has no impact on program run
Thanks for your response.
So I need to study estop_latch
- Thank you received: 5934
16 Feb 2021 17:25 #199090
Replied by tommylight on topic VFD error has no impact on program run
Might have to set the "ramp down" to give more time for the spindle to slow down, done on the VFD.I recently added a braking resistor and now I have quite often Err4 when braking.
The error signal has to also be wired to one of the control inputs in HAL, like suggested to e-stop or machine enable, or if there is spindle-amp-fault. I am sure the 2.8 and master have amp-fault inputs as i have them in use, but i use no spindle so never checked.The error is correctly display in my custom panel but this has not impact in LinuxCnc.
Time to create page: 0.509 seconds
