Setting up HALUI
- madguernseyboy
07 Mar 2021 15:47 #201301
by madguernseyboy
Setting up HALUI was created by madguernseyboy
Hi all
This used to work on version 2.7. i am upgrading to 2.8 and now i cant get it to work.
I get the following error
postgui_call_list.hal:10: Pin 'halui.mdi-command-00' does not exist
Can someone point out my mistake?
Files attached.
Thank you
Files attached.
Thank you
- madguernseyboy
07 Mar 2021 16:14 #201304
by madguernseyboy
Replied by madguernseyboy on topic Setting up HALUI
ok so i realised i forgot the command in my ini file
HALUI = halui
but it still doesn't work.
HALUI = halui
07 Mar 2021 16:52 #201312
by Grotius
Replied by Grotius on topic Setting up HALUI
If you have enabled Halui, you could see the port and pins in halshow before even adding a pin in your
postgui_call_list.hal file.
If you see halui is working, then you can try to connect it in your halfile.
- madguernseyboy
07 Mar 2021 21:09 - 07 Mar 2021 21:11 #201359
by madguernseyboy
I managed to get it to work.
I re-ran stepconfig and used that to install HALUI and Pyvcp
Now it works. just it cant find my 0<files> now.
step in the right direction i suppose
Last edit: 07 Mar 2021 21:11 by madguernseyboy.
08 Mar 2021 08:53 #201400
by Grotius
What do you mean with 0<files> ?
08 Mar 2021 13:43 #201424
If they were in the config folder then they should be in a backup folder in there after a 2.8 conversion.
If they were i the nc_files folder, then they should still be there.
Unless you did a clean install of OS and LinuxCNC in which case they will be gone unless you keep backups.
Replied by andypugh on topic Setting up HALUI
- madguernseyboy
08 Mar 2021 15:51 #201439
by madguernseyboy
All fixed.
I made the mistake of calling my subroutines o100.ngc
when the should be 100.ngc
Time to create page: 0.174 seconds
