[SOLVED] sendkeys help {manual error, corrrected}
18 Mar 2021 20:56 - 20 Mar 2021 19:46 #202765 by robertspark
all down to a manual error...... thanks for your help, I would have NEVER got that one!
Last edit: 20 Mar 2021 19:46 by robertspark.
19 Mar 2021 01:28 #202799 by andypugh
Replied by andypugh on topic sendkeys help
Odd, it seems to be being compiled (this is an extract from the buildbot log)
Compiling hal/user_comps/sendkeys.c
gcc -c -I. -Ilibnml/linklist -Ilibnml/cms -Ilibnml/rcs -Ilibnml/inifile -Ilibnml/os_intf -Ilibnml/nml -Ilibnml/buffer -Ilibnml/posemath -Irtapi -Ihal -Iemc/nml_intf -Iemc/kinematics -Iemc/tp -Iemc/motion -Iemc/ini -Iemc/rs274ngc -Iemc/sai -Iemc/pythonplugin -Iemc/tooldata -I/home/buildslave/emc2-buildbot/buster-rtpreempt-amd64/rip-buster-rtpreempt-amd64/build/src/include -I/usr/include/python2.7  -Os -fwrapv  -g -Wall  -DULAPI -std=gnu99 -fgnu89-inline -Werror=implicit-function-declaration -g -O2    \
	-MP -MD -MF "objects/hal/user_comps/sendkeys.d" -MT "objects/hal/user_comps/sendkeys.o" \
	hal/user_comps/sendkeys.c -o objects/hal/user_comps/sendkeys.o
Preprocessing thermistor.comp
buildbot.linuxcnc.org/buildbot/builders/...s/compile/logs/stdio
And it seems to appear in the .deb files that I have built (so I would expect it to be in the buildbot ones)
andypugh@rm-one:~$ dpkg -c linuxcnc_2.9.0~pre0_amd64.deb | grep sendkeys
-rwxr-xr-x root/root     14608 2019-06-02 23:52 ./usr/bin/sendkeys
-rw-r--r-- root/root      2316 2019-06-02 23:52 ./usr/share/man/man1/sendkeys.1.gz
The following user(s) said Thank You: robertspark
19 Mar 2021 18:58 #202878 by robertspark
Replied by robertspark on topic sendkeys help
back to the drawing board tonight..... determined to figure this out and get it working...
19 Mar 2021 20:20 - 19 Mar 2021 20:29 #202889 by robertspark
being a smart A£$£, I thought I'd just download sendkeys.c from linuxcnc git and run halcompile....
I ended up with this...
rob@RobsCNC:~/Downloads$ sudo halcompile --install sendkeys.c
[sudo] password for rob:
Compiling realtime sendkeys.c
sendkeys.c: In function ‘main’:
sendkeys.c:202:5: warning: implicit declaration of function ‘signal’; did you mean ‘strsignal’? [-Wimplicit-function-declaration]
     signal(SIGINT, exit_handler);
     strsignal
sendkeys.c:202:12: error: ‘SIGINT’ undeclared (first use in this function); did you mean ‘SW_CNT’?
            SW_CNT
sendkeys.c:202:12: note: each undeclared identifier is reported only once for each function it appears in
sendkeys.c:203:12: error: ‘SIGTERM’ undeclared (first use in this function)
     signal(SIGTERM, exit_handler);
make: *** [/usr/share/linuxcnc/Makefile.modinc:116: sendkeys.o] Error 1
am I doing something wrong?
where should I look for sendkeys.c on an linuxcnc.iso && upgrade to master via buildbot? {I check for updates daily, so its always on the latest master}
Last edit: 19 Mar 2021 20:29 by robertspark.
19 Mar 2021 21:52 #202900 by andypugh
That really shouldn't be necessary. But also should work.
I think that you might need the kernel headers to compile it.
To be honest I think that the best fix it so figure out why you are not getting the compiled module automatically with LinuxCNC.
19 Mar 2021 21:57 #202901 by andypugh
I can't compile it with halcompile either, by the way. I think that it needs to be given the paths to various includes that halcompile doesn't do.
It compiles OK as part of a full LinuxCNC install.
19 Mar 2021 23:09 #202908 by robertspark
nope,
I've given it the paths to all of the includes:
#include </usr/include/linuxcnc/rtapi.h>
#include </usr/include/linuxcnc/hal.h>
#include <linux/uinput.h>
#include </usr/include/linux/unistd.h>
#include </usr/include/linux/fcntl.h>
#include </usr/include/stdio.h>
#include </usr/include/c++/8/stdlib.h>
#include </usr/include/linux/string.h>
No dice.
sendkeys.c: In function ‘emit’:
sendkeys.c:65:4: warning: implicit declaration of function ‘write’; did you mean ‘fwrite’? [-Wimplicit-function-declaration]
    write(fd, &ie, sizeof(ie));
    fwrite
     strsignal
            SW_CNT
sendkeys.c:225:29: warning: implicit declaration of function ‘open’; did you mean ‘popen’? [-Wimplicit-function-declaration]
                 param->fd = open("/dev/uinput", O_WRONLY | O_NONBLOCK);
                             popen
No sendkeys.o within /usr/lib/linuxcnc/modules/
rob@RobsCNC:/usr/lib/linuxcnc/modules$ ls s*
sample_hold.so   serport.so            sim_parport.so      steptest.so
sampler.so       setsserial.so         simple_tp.so        streamer.so
scale.so         siggen.so             sim_spindle.so      sum2.so
scarakins.so     sim_axis_hardware.so  sphereprobe.so      supply.so
scope_rt.so      sim_encoder.so        spindle_monitor.so
scorbot-kins.so  sim_home_switch.so    spindle.so
select8.so       sim_matrix_kb.so      stepgen.so
this was after removing (completly) linuxcnc using synaptic and reinstalling from buildbot master moments ago.
baffled!
{thanks for your help / taking the time to check this thread out it is much appreciated}
19 Mar 2021 23:17 #202909 by robertspark
just for fun.....
I did a complete removal of linuxcnc again using synaptic and reinstalled 2.8.1 from buildbot.....
am I missing something as a noob?
20 Mar 2021 00:42 #202919 by andypugh
Is "thermistor" there?
If you grab the deb directly from the buildbot, can you see the file in it with dpkg -c ?
dpkg -c //name//of//deb//file// | grep sendkeys
buildbot.linuxcnc.org/dists/
20 Mar 2021 11:54 - 20 Mar 2021 12:19 #202969 by robertspark
no {not in 2.8.1 & master }
rob@RobsCNC:/usr/lib/linuxcnc/modules$ ls t*.*
thc.so      threadtest.so  time.so         tripodkins.so      trivkins.so
thcud.so    timedelay.so   toggle2nist.so  tristate_bit.so
threads.so  timedelta.so   toggle.so       tristate_float.so
Could I be missing a dependency? [I would have thought that any dependencies for linuxcnc would be installed by default as part of the linuxcnc.iso install from bootable usb?
I have the following installed:
linuxcnc-doc-en
linuxcnc-uspace
linuxcnc-uspace-dev
do I need to install linuxcnc-uspace-dbsym??? (what are the debug symbols for?)
well sendkeys is within the *.deb..... but at what point is it compiled to a sendkeys.so module?
rob@RobsCNC:~/Downloads$ dpkg -c linuxcnc-uspace_2.9.0~pre0.3688.ge6aec2fd2_amd64.deb | grep sendkeys
-rwxr-xr-x root/root     14592 2021-03-20 07:44 ./usr/bin/sendkeys
-rw-r--r-- root/root      2313 2021-03-20 07:44 ./usr/share/man/man1/sendkeys.1.gz
anyway to run an install giving a complete output of what was installed
One hell of a mystery!
rob@RobsCNC:/$ sudo find -name 'sendkey*.**'
./home/rob/Downloads/sendkeys.c
rob@RobsCNC:/$
Last edit: 20 Mar 2021 12:19 by robertspark.
Time to create page: 0.191 seconds
