[SOLVED] sendkeys help {manual error, corrrected}
20 Mar 2021 18:53 - 20 Mar 2021 18:53 #203008
Replied by andypugh on topic sendkeys help
thermistor and sendkeys are both userspace components.
That means that they are just ordinary executables.
Have you tried looking for them _without_ the .so or .ko suffix?
Last edit: 20 Mar 2021 18:53 by andypugh.
20 Mar 2021 18:55 #203010
Does "loadusr sendkeys" in a HAL file (or halcmd session) work?
I have assumed that you are looking for the files because you can't load the modules. But I have just realised that you never actually said that.
- robertspark
- Thank you received: 216
20 Mar 2021 19:01 - 20 Mar 2021 19:02 #203015
by robertspark
yes that is correct.
No, it fails to load {I'll try again now and post the error report}
Replied by robertspark on topic sendkeys help
rob@RobsCNC:/$ sudo find -name 'sendkeys.*'
./home/rob/Downloads/sendkeys.c
./usr/share/man/man1/sendkeys.1.gz
rob@RobsCNC:/$ sudo find -name 'thermistor.*'
./usr/src/linux-headers-4.19.0-14-rt-amd64/include/config/sensors/ntc/thermistor.h
./usr/share/man/man1/thermistor.1.gz
rob@RobsCNC:/$
Last edit: 20 Mar 2021 19:02 by robertspark.
20 Mar 2021 19:06 #203016
_What_ is correct?
Is it correct that "loadusr sendkeys" does not work?
If you do the following, what is the output?
...oops! I have just noticed that the sendkeys manpage is wrong!
Sendkeys is a userspace comp, the command to load it is "loadusr". The manual says "loadrt"
Your search for "sendkeys.*" won't find "sendkeys". You could try looking for "sendkeys*"
halrun
loadusr sendkeys config=s8t5
- robertspark
20 Mar 2021 19:09 #203017
by robertspark
hang on......
is sendkeys a realtime component or a userspace component???
manual says
loadrt sendkeys config=s8t5, 16, t12
linuxcnc.org/docs/devel/html/man/man1/sendkeys.1.html
and also says:
Am I loading it wrong?
manual says
and also says:
The config parameter to the loadrt HAL command defines
loadrt sendkeys config=t2
setp sendkeys.0.pin-event-00 29 # Left Ctrl
setp sendkeys.0.pin-event-01 57 # Space
setp sendkeys.0.init 1
- robertspark
20 Mar 2021 19:11 #203018
by robertspark
wow, that was hard work...
rob@RobsCNC:~$ halrun
halcmd: loadusr sendkeys config=s8t5
halcmd: sendkeys: inst 1 codes 8 triggers 5
20 Mar 2021 19:25 #203020
It did. Sorry, it is fixed now.
The example section in the manpage was right...
hmanual says
Time to create page: 0.224 seconds
