Disable/increase following error during hominh
17 Oct 2021 15:45 #223393
by kimachren
Disable/increase following error during hominh was created by kimachren
Is it possible to disable or change the following error during homing? The X-slide on my lathe is set up with two inductive sensors as limit switches. Both sensors are also wired to the servo drive's R-/L-Inhibit inputs, so the motor stops when hitting a switch, no matter what. The problem comes when I try to home on the limit+ sensor. The drive sometimes stops the motor before linuxcnc gets the signal and it throws a following error.
Only other way to solve this that I can think of, is to somehow disable the Inhibit input on the drive.
- Thank you received: 5966
17 Oct 2021 20:12 #223413
Replied by tommylight on topic Disable/increase following error during hominh
That should normally work as is if the wiring is OK and if the drives do not fault when any of the switches is triggered, they should just inhibit the motion on one direction, not both.
For testing:
change the home_latch_velocity to negative or positive by adding or removing a -
same for home_final_velocity
if any of those are not correct the homing procedure will fail.
For testing:
17 Oct 2021 21:47 #223417
Replied by rodw on topic Disable/increase following error during hominh
I think if the motor is going to be disabled by hardware wiring when it hits a shared home/limit switch, you probably need a seperate home switch.
17 Oct 2021 22:10 #223421
I did the same thing on the Hurco, it works.
Yaskawa does not disable them, for sure.
Also i am sure having the above mentioned values reversed will just plain halt the machine, and having them reversed is always easy, depending on the info set in PncConf.
18 Oct 2021 14:27 - 18 Oct 2021 14:31 #223455
by kimachren
Replied by kimachren on topic Disable/increase following error during hominh
The thing is - it work about two of three times, and when it doesn't, I just have to override limit switches, re-enable the system and push Home All again.
The Inhibit signals just prevents the motors from turning any further to that direction. Ie. when R Inhibit is activated, the motor can only turn to L direction.
Last edit: 18 Oct 2021 14:31 by kimachren.
18 Oct 2021 14:46 #223460
It will also need to have a small value of
home_offset
so it moves off the switch after homing, usually 2 to 3mm are enough.
home_offset
18 Oct 2021 17:32 #223482
by kimachren
Sorry that I didn't mention it before, but the axis uses index-homing, so when it works, it finds the limit switch and reverses slowly searching for the insex pulse.
24 Oct 2021 22:13 #224127
linuxcnc.org/docs/2.8/html/man/man1/milltask.1.html
Using a mux2:
linuxcnc.org/docs/2.8/html/man/man9/mux2.9.html
Controlled by joint.N.homing:
linuxcnc.org/docs/2.8/html/man/man9/motion.9.html
Replied by andypugh on topic Disable/increase following error during hominh
Yes. You could drive the ini.N.f-error pins:Is it possible to disable or change the following error during homing?
Using a mux2:
The following user(s) said Thank You: arvidb
29 Oct 2021 13:55 #224650
by kimachren
Thanks Andy
That was exactly what I was looking for. I didn't even realize there were hal oins for the ini.
Time to create page: 0.123 seconds
