RPI4b Revision 7 not supported by HAL_PI_GIO
12 Jul 2023 15:24 #275286
by itsme
RPI4b Revision 7 not supported by HAL_PI_GIO was created by itsme
I received a new Raspberry 4b (4Gig) and after switching it with an older one Linuxcnc refuses to start.
There is an error message that Revision 7 is not supported by HAL_PI_GPIO...
How can this be resolved?
16 Jul 2023 15:17 #275572
by elovalvo
Replied by elovalvo on topic RPI4b Revision 7 not supported by HAL_PI_GIO
The problem is that the cpuinfo.c module needs to be updated.
To temporarily overcome the problem, copy the file /proc/cpuinfo in /tmp with the following command:
Edit the contents of the /tmp/cpuinfo.txt file by changing the Revision to this
Revision: c03112
and then use the following command
and start LinuxCNC.
However it would be useful to completely review the functioning of the cpuinfo.c and hal_pi_gpio module as suggested in this link www.raspberrypi.com/documentation/comput...ry-pi-revision-codes
Let me know what revision your new Raspberry has.
To find out you need to type
cp /proc/cpuinfo /tmp/cpuinfo.txt
Revision: c03112
mount --bind /tmp/cpuinfo.txt /proc/cpuinfo
and start LinuxCNC.
cat /proc/cpuinfo | grep Revision
16 Jul 2023 15:44 #275575
cpuinfo.c was changed last night.
github.com/LinuxCNC/linuxcnc/commit/2cb7...602d279d0bf5aca40e26
Replied by andypugh on topic RPI4b Revision 7 not supported by HAL_PI_GIO
The following user(s) said Thank You: elovalvo
16 Jul 2023 16:04 - 16 Jul 2023 16:05 #275576
by itsme
Replied by itsme on topic RPI4b Revision 7 not supported by HAL_PI_GIO
Here is my cpuinfo:
Hardware : BCM2835
Revision : c03115
Serial : 10000000eeeXXXXX
Model : Raspberry Pi 4 Model B Rev 1.5
Last edit: 16 Jul 2023 16:05 by itsme.
16 Jul 2023 16:11 #275577
by itsme
I downloaded the corresponding files from github and used halcompile to generate the .so file.
Then i copied the file to /usr/lib/linuxcnc/modules.
unfortunately i still have an error on startup of Linuxcnc:
hal_pi2_gpio: dlopen: /usr/lib/linuxcnc/modules/hal_pi2_gpio.so: undefined symbol: get_rpi_revision
./RPI-mill.hal:39: waitpid failed /usr/bin/rtapi_app hal_pi2_gpio
./RPI-mill.hal:39: /usr/bin/rtapi_app exited without becoming ready
./RPI-mill.hal:39: insmod for hal_pi2_gpio failed, returned -1
16 Jul 2023 16:17 #275578
by elovalvo
Did you try the workaround given here?
forum.linuxcnc.org/24-hal-components/495...by-hal-pi-gio#275572
Here is my cpuinfo:
Hardware : BCM2835 Revision : c03115 Serial : 10000000eeeXXXXX Model : Raspberry Pi 4 Model B Rev 1.5
The following user(s) said Thank You: itsme
16 Jul 2023 16:32 #275580
by itsme
I now tried the given workaround and this works well with the unmodified HAL_PI_GPIO.
Thank you!
Thank you!
16 Jul 2023 16:59 #275585
by itsme
Unfortunately this workaround is not persistent, after a reboot the cpuinfo is reset by the system and the workaround has to be done again to make LCNC start.
16 Jul 2023 17:20 - 16 Jul 2023 17:30 #275587
by elovalvo
While waiting for Andy to complete his precious work, download this file to the Raspberry then run the following commands:
and LinuxCNC will always start at the command:
P.S. the system changed the file name by adding day and year. Once downloaded rename it startcnc.txt deleting the addition
startlcnc.txt[/attachment]itsme post=275585 userid=28738"]Unfortunately this workaround is not persistent, after a reboot the cpuinfo is reset by the system and the workaround has to be done again to make LCNC start.
sudo cp startlcnc.txt /usr/local/bin/startlcnc
sudo chmod a+x /usr/local/bin/startlcnc
startlcnc
Last edit: 16 Jul 2023 17:30 by elovalvo.
16 Jul 2023 20:57 #275597
by itsme
Thank you for your suggestion! I have not tested it yet, but I assume it will not work as expected.
The tmp folder is purged on startup...
Time to create page: 0.173 seconds
