RPI4b Revision 7 not supported by HAL_PI_GIO
21 Jul 2023 14:49 #275956
by elovalvo
Yes, indeed tmp folder is purged on startup.
And in fact the procedure copies the file on tmp every time before starting LinuxCNC ...
Replied by elovalvo on topic RPI4b Revision 7 not supported by HAL_PI_GIO
Thank you for your suggestion! I have not tested it yet, but I assume it will not work as expected.
The tmp folder is purged on startup...
21 Jul 2023 16:44 #275965
by itsme
Replied by itsme on topic RPI4b Revision 7 not supported by HAL_PI_GIO
Ok, I miss the part where cpuinfo is changed...
Time to create page: 0.111 seconds
