JoyPad input pins missing from 2.9.2 ?
14 Mar 2024 23:18 - 14 Mar 2024 23:19 #295922
by nottolino
JoyPad input pins missing from 2.9.2 ? was created by nottolino
Hi all.
I'm currently running linuxcnc 2.9.2 on debian bookworm on a , after an unsuccessful attempt on 2.8 which gave me some problems.
My joypad, which was working on 2.8, do not work anymore.
The input pins are apparently missing from HAL in 2.9.2
ottorino@8-CNC:~$ halcmd show pin input
Component Pins:
Owner Type Dir Value Name
I'm afraid I'm missing something obvious here.
The hardware spec are attached hereunder
Component Pins:
Last edit: 14 Mar 2024 23:19 by nottolino. Reason: too long a link
- Thank you received: 5932
16 Mar 2024 00:45 #296012
Replied by tommylight on topic JoyPad input pins missing from 2.9.2 ?
Changed the tittle to reflect the use of joypad.
16 Mar 2024 15:23 #296068
by Unlogic
Replied by Unlogic on topic JoyPad input pins missing from 2.9.2 ?
I think 2.9.x brought some changes in pin names related to joints and axis.
16 Mar 2024 18:44 #296083
Replied by cmorley on topic JoyPad input pins missing from 2.9.2 ?
We need more info. Is it a usb joypad? hoiw are you loading the driver?
Maybe include your config files.
17 Mar 2024 14:55 #296143
by jtrantow
Replied by jtrantow on topic JoyPad input pins missing from 2.9.2 ?
Quite a while ago, I updated the wiki for a logitech joypad for the 2.8 and 2.9 releases. The only joypad change was
LinuxCNC
2.9 renames btn-joystick to btn_trigger. I am using this on several machines with the latest 2.9 without problems.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant
Time to create page: 0.078 seconds
