Update ClassicLadder
02 Dec 2015 15:53 #66211
by Tomasz_K
Update ClassicLadder was created by Tomasz_K
Is it planned to update the ClassicLadder to latest version (2015-05-30
Sourceforge
The following user(s) said Thank You: reliantkill
03 Dec 2015 15:09 #66282
by LAIR82
I wouldn't mind seeing this happen as well.
CL that comes with LCNC has rungs smaller than the latest CL. Our version of CL is 6 bits tall by 10 bits wide, latest version of CL is 8 bits tall by 12 bits wide. This would allow more I/O per rung.
And it allows you to use your mouse to click and drag to select/copy/move parts of your logic.
But, I'm not near capable enough to help accomplish this, and the guys that are, I'm sure are busy, and have bigger fish to fry than this issue,
Rick
Replied by LAIR82 on topic Update ClassicLadder
Is it planned to update the ClassicLadder to latest version (2015-05-30 Sourceforge )
Rick
03 Dec 2015 18:54 #66309
Replied by cmorley on topic Update ClassicLadder
There are no recent plans. I did the last conversion - it's alot of work.
Also we have done alot of bug fixing and not all of it got to CL in the form we added it.
and finally the very latest CL has internal changes that IIRC makes it even harder to convert.
There is much newer version that could be added to linuxcnc, I just didn't see improvements big enough to make it seem worth the trouble.
Maybe I will look at it again.
Chris M
Chris M
03 Dec 2015 19:38 #66314
by LAIR82
I remember you saying it was a lot of work to get it integrated into linuxcnc, and just wishful thinking on my part,
I know you guys are busy with more pressing things than this,
Those are the only real differences that I have found between the two versions of classicladder.
Rick
Chris M
Rick
05 Dec 2015 07:14 - 05 Dec 2015 08:03 #66442
by Tomasz_K
Replied by Tomasz_K on topic Update ClassicLadder
Maybe it is time to change the ClassicLadder to another SoftPLC?
Example beremiz ( Presentation ) seems OK.
Last edit: 05 Dec 2015 08:03 by Tomasz_K.
- reliantkill
05 Jan 2016 09:59 #67912
by reliantkill
Replied by reliantkill on topic Update ClassicLadder
Beremiz looks like a pretty complete package, I have not found the manual or documentation
any links that someone can provide?
05 Jan 2016 10:14 #67915
by cncbasher
Replied by cncbasher on topic Update ClassicLadder
wish it was better written , it seems a mess ,
17 Jan 2017 18:47 #85975
by sinusvag
Replied by sinusvag on topic Update ClassicLadder
22 Apr 2017 06:58 - 22 Apr 2017 07:25 #91832
by Tomasz_K
Developers Beremiz still hard working.
Beremiz is an integrated development environment for machine automation. It is Free Software, conforming to IEC-61131 among other standards, like this:
Modbus, EtherCAT, CANopen
This project still live.
CL seems die
I hope either will improve, or developers will change it to a newst PLC system.
CL seems die
Last edit: 22 Apr 2017 07:25 by Tomasz_K.
