Classic Ladder crashing
11 Feb 2024 04:08 #293056
by spumco
Classic Ladder crashing was created by spumco
Just tried editing my ladder and after clicking on one of the rungs the ladder interface - all windows - closed.
LCNC did not close or show an error.
Restarted PC and tried again watching the terminal. Crapped out again after I made & saved a few changes, no warning.
Anyone see 'stack smashing detected' before?
creating ladder-state
command (EMC_TASK_PLAN_EXECUTE) cannot be executed until the machine is out of E-stop and turned on
note: MAXV max: 3.000 units/sec 180.000 units/min
note: LJOG max: 3.000 units/sec 180.000 units/min
note: LJOG default: 0.500 units/sec 30.000 units/min
note: AJOG max: 3600.000 units/sec 216000.000 units/min
note: AJOG default: 180.000 units/sec 10800.000 units/min
note: jog_order='ZXCV'
note: jog_invert=set()
*** stack smashing detected ***: terminated
task: 28418 cycles, min=0.000008, max=0.035563, avg=0.010065, 0 latency excursions (> 10x expected cycle time of 0.010000s)
iov2: exiting
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Note: Using POSIX realtime
lathe@lathe:~$
11 Feb 2024 04:35 #293059
Replied by cmorley on topic Classic Ladder crashing
Can you give info on the system and linuxcnc versions?
11 Feb 2024 05:01 #293060
by spumco
Debian Trixie
Kernel 6.6.0-rt14
LCNC 2.9.2
Mesa 7i96s/7i85s/7i84d/7i73
Updated LCNC three days ago.
Replied by spumco on topic Classic Ladder crashing
PC - Mele Quieter 3Can you give info on the system and linuxcnc versions?
Debian Trixie
Kernel 6.6.0-rt14
LCNC 2.9.2
11 Feb 2024 05:40 - 11 Feb 2024 05:43 #293062
by spumco
A bit more info...
Was able to create, edit & save another ladder section. Ladder was working as expected and interacting with LCNC.
The crash was duplicated when I clicked in the section display on a variable comparison box. Could click anywhere in any of the sections... but the second I clicked on the comparison box all the ladder windows disappeared.
If I open the editor I can edit the comparison box... but clicking on it with the editor closed fails.
No 'stack smashing detected' terminal error messages were generated after the first crash. All subsequent crashes the terminal was silent.
Last edit: 11 Feb 2024 05:43 by spumco.
24 Feb 2024 05:10 #294173
by spumco
Same crash just happened on my LCNC VM installation (under Win10).
Exactly the same behavior, different kernel. Both using XFCE.
Start LCNC, open Ladder Editor. Click on a variable box in the rung display...
All ladder windows close, no activity in the terminal, and CL can't be reopened without re-starting LCNC.
Linux lathe 6.1.0-13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.55-1 (2023-09-29) x86_64 GNU/Linux
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Time to create page: 0.570 seconds
