Stepper to Servo upgrade
10 Jul 2013 14:48 #36484
by samitr
Re:Large Lathe Retrofit was created by samitr
bumping this year old thread to check for advice on upgrading stepper setup
to servo using Panasonic AC Servo drives MINA A4.
10 Jul 2013 21:53 #36507
Replied by andypugh on topic Re:Large Lathe Retrofit
Bumping an old thread is almost never the best way, especially as that topic had drifted.
Do you have any specific questions about your upgrade?
11 Jul 2013 00:13 #36520
by BigJohnT
Replied by BigJohnT on topic Re:Large Lathe Retrofit
At first I didn't look close but there is no bump which make no sense to say your bumping an old thread...
JT
JT
11 Jul 2013 00:16 #36521
I moved it. But forgot to say so .t there is no bump
11 Jul 2013 00:28 #36524
by BigJohnT
Now it all make sense
JT
JT
14 Jul 2013 04:48 #36630
by jmelson
You first need to find out what command inputs the drives can take, and
then which of those you want to use. Then we can advise further.
Jon
Replied by jmelson on topic Re:Large Lathe Retrofit
These drives probably can be set up for step/direction or velocity servo.bumping this year old thread to check for advice on upgrading stepper setup
Jon
The following user(s) said Thank You: samitr
14 Jul 2013 22:39 #36641
by samitr
Replied by samitr on topic Re:Large Lathe Retrofit
the Minas drivers take step direction pulses,
planning to hook them up in open loop like a stepper.
i was trying to find out how fast the signals need to go
to get the motors going at their peak speeds (could not get much from the manual).
there are two inputs on the driver one for <500kpps (other can take upto 2Mpps)
i think i should be able to get 25-30kpps from emc
got to see if that will be juice enough for the motors.
guess i got to wire the signals to find out, just dont want to fry anything.
apologies for the non bump - bump
Regards
Regards
14 Jul 2013 23:23 #36643
If you find that you need more than 30kpps then there are boards from Pico and Mesa that connect to the parallel port and supply MHz pulse rates.
Moderators: piasdom
Time to create page: 0.172 seconds
