Semi-Manual Lathe
18 Jan 2014 17:23 #42961
by lelef
Replied by lelef on topic Semi-Manual Lathe
ok,,
G96 D1500 S#2 ; Constant Surface Speed Mode it dosn't work changing spindle speed?
18 Jan 2014 23:26 #42971
Replied by andypugh on topic Semi-Manual Lathe
Can you rephrase your question in the form of a question?
19 Jan 2014 02:20 #42977
by lelef
I've not understood, if the G96 is a command to change the spindle speed to have a costant cutting speed this should be the problem with my lathe, because I can't control the spindle speed.
19 Jan 2014 02:29 #42979
In G96 mode the value of the HAL pin "motion.spindle-speed-out" varies according to the diameter of the work. If your configuration ignores this pin then it doesn't matter.
Moderators: piasdom
Time to create page: 0.169 seconds
