Nardini ms1440 s lathe conversion.
- eneias_eringer
- Thank you received: 7
11 Nov 2014 20:38 - 11 Nov 2014 20:41 #53013
by eneias_eringer
Replied by eneias_eringer on topic Nardini ms1440 s lathe conversion.
Are 52kgf steppers with encoders.
This machine is only to machining glass polishing wheels, that is so soft, not for metals , the rapids not very important , i use steppers with encoders and following error by linux cnc , becouse the material is a mix of grubber and abrasive , and is constant that x axis lock with the dirt , so if this happen linux cnc stop with a alarm.
Because the velocity limit of parallel port to read encoders , the rapid z is 2000mm/min max too , i think whit no encoder i could 3000 to 4000mm/min
This is another lathe for the same company this video is machining the polishing wheels , (no security iet only tests)
This is another Lathe that i make with 100kgf steppers and 25x10mm ballscrew 6000mm/min this for metals !!!
Last edit: 11 Nov 2014 20:41 by eneias_eringer.
11 Nov 2014 21:26 #53015
In that case, have you considered using a Mesa 5i25 in place of the parallel port? That has the same physical layout as a parallel port, but can count encoders and make pulses at Mhz rather than kHz, costs about $80 and is fully supported by LinuxCNC.
Replied by andypugh on topic Nardini ms1440 s lathe conversion.
- eneias_eringer
11 Nov 2014 21:39 #53016
by eneias_eringer
I live in Brasil , and to me anything is more expansive and have more delay , they send to Brasil ? I would like to make some test with it !!
Moderators: piasdom
