Hardinge Superslant retrofit project. What sort of pendant?
20 Jun 2017 01:14 #94715
by Vitran
I have been busy at rebuilding a Hardinge Superslant and am wondering about what sort of operator inputs people use and like? I don't have many inputs left, so I want to know what I can do. I am removing the old panel and putting in a screen and keyboard in its place.
Recently I came to the startling conclusion that the encoder on the turret could not be used by the encoder on the 7i77 Mesa card I have. The encoders in question run on 12VDC and are a 4 wire output for the two turrets. This lost me 8 input wires, taking up nearly all the inputs I had left on the 7i64 and leaving me with 1 input left. I can use 5 more from the parallel port.
As is, the operator inputs I have are:
- Start cycle
- Stop cycle
- Single Block
- Open collet
- Close collet
- One rotary encoder
I have been looking at the pendants available, but wondering what people use and like?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...Wireless_MPG_Pendant
In my case I have a few things I really want to do. I want to be able to index the turret and the tailstock to change tools but I may have to do that on the screen. Change between which axis I am moving (XZ + Z tailstock). I would love a feed, travel, and spindle speed control, however this is all way too many inputs for my setup.
What do other people have and what have they done?
- Start cycle
- Stop cycle
- Single Block
- Open collet
- Close collet
20 Jun 2017 22:52 #94746
Replied by andypugh on topic Hardinge Superslant retrofit project. What sort of pendant?
If you are using a 5i25 then you have an extra 25-pin header on the card. You can connect a 7i74 to that, and then 8 more smart-serial cards. Or you can connect a generic parallel port breakout to that header.
Alternatively you might be able to save some inputs by using matrix-wiring. There is a HAL component that can help there:
linuxcnc.org/docs/2.7/html/man/man9/matrix_kb.9.html though I don't know if anyone has ever used it.
23 Jun 2017 03:03 #94818
by Vitran
Replied by Vitran on topic Hardinge Superslant retrofit project. What sort of pendant?
I am using a 6i25. I will look into using a secondary card. I didn't know if going for a second card was the best option, or if someone has found a good pendant to use with a lathe. If it was a mill I'd go pendant, but the lathe is a little more tricky I think.
23 Jun 2017 10:52 - 23 Jun 2017 10:53 #94828
I like to keep my jogwheels entirely in realtime, which means that the USB-connected MPGs from eBay are out.
For a lathe there is a lot to be said for individual jogwheels for X and Z. On my lathe I actually mounted these on the saddle apron. That might not be so convenient with the enclosure on your lathe ( Colchester have a way round this ) on some lathes with a console that passes round or through the guarding attached to the saddle. But I would not think there is any advantage in copying that on a lathe not built that way.
My jogwheels (and the limit switches in the saddle, and an extra button/knob) are interfaced to a 7i73 mounted inside the saddle castings. But you can't easily do that without adding at least one RS232 port.
You probably have a set of bare encoder inputs which could be used for three MPGs on your spare connector on the 5i25.I think the 5i25 pins are 5V-tolerant, but you would need to check. Only 3 MPGs, because the encoders on the 7i77 are multiplexed, two physical encoders share one set of ABZ pins.
Last edit: 23 Jun 2017 10:53 by andypugh.
23 Jun 2017 12:47 #94834
by Vitran
I have two encoders open so I can do X and Z motions with the wheels and that is certainly an option. I have one jog wheel left over from the front panel. The currently used encoders are on X, Z, Tailstock, and Spindle.
I can have two encoders for XZ and the last input for switching control between tailstock and carriage.
I was hoping there was some kind of USB input card that could handle less-than-real-time input for controlling rapid / feed / rpm and rotating the turrets.
23 Jun 2017 12:58 #94837
Pokeys, maybe?
forum.linuxcnc.org/24-hal-components/29816-pokeys#64207
Personally I don't like the idea of my jog-device freezing on if the GUI gets busy, so prefer to jog via HAL/realtime.
Pokeys, maybe?
23 Jun 2017 16:28 #94856
by Vitran
At this point, if I was serious I would get the cable/bracket kit from Mesa to use the second port connection on the 6i25 to get me the other inputs I desire. As much as spending more time on the design, I want to get the machine moving first before diving into the interface more. I will wire in two hand wheel encoder inputs but not connect anything yet.
If there are some other USB I/O boards that can just plug in to be a pendant I would likely go for that before getting an expansion card.
24 Jun 2017 01:13 #94876
The 7i64 that you have is very good, but expensive. Have you noticed that some of the other Mesa cards are cheaper than USB cards?
25 Jun 2017 03:39 #94906
by Vitran
I am more following advice from what I read and see. This is my first time going into Mesa/FPGA route instead of a parallel port breakout to do step/dir on a mill. At this point price of a solution isn't as much of a concern as getting a product that I have to deal less thought with. If it cost even $500 and the machine was done and operational without programming, I'd likely go for it. If a $200 pendant already interfaces with LinuxCNC and does what I need and is ready to go as opposed to wiring, the $200 pendant seems a good choice.
I think now that the 7i64 was an okay choice for the machine. A 7i73 may have been a better option, but I was worried about the payoff of how much time it would take to learn and modify code to meet my needs instead of doing something (potentially) simpler that I know how to do (organize wiring diagrams and put wires in spots). I have a few projects that have ended at the point where I just can't get the code to do what I need it to / upload / compile as needed and have gone away from those in the future. This is also what I am afraid of if I went to a USB port that wasn't a complete package.
I want a feed%/rapid%/rpm% control, but looking at the old control panel dials they had 5 bit interface for the feed and rapid and a 3 bit for the rpm which is a lot of input ports. I'll use the screen and keyboard hotkeys for those and coolant.
If there is no easy solution, then so be it. I didn't know if there was a ready-made thing for LinuxCNC out there. As well, I am nowhere near done. I have what I think of as a mountain of work to get the I/Os for the various sensors and turrets wired right. That may be the bigger task at this time.
25 Jun 2017 07:28 #94910
Replied by rodw on topic Hardinge Superslant retrofit project. What sort of pendant?
These guys do a Mesa compatible Wireless Pendant
xhctech.en.alibaba.com/
6 axis, 3 scales, estop, a DIN rail relay box to go in the cabinet and a small antenna with a magnetic mount.
Delivered to Australia was USD $352
Some details on my build up here.
forum.linuxcnc.org/show-your-stuff/32029...tter-build?start=150
There are 3 spare buttons you can use as you like. Correct part number is ATWGP-01-6BB-3 which says, 5v, 2 wire Mesa compatible MPG and coded selection outputs which save a pin or two. I can share an email address if interested.
I have briefly tested this and it seems quite OK and responsive enough. It was pretty easy to set up in HAL.
Moderators: piasdom
