tool orientation not changing
22 Oct 2017 23:18 #100639
by Ross77
tool orientation not changing was created by Ross77
So I'm trying to setup the tool table but only the offset seems to work. If i change the orientation and add the front and back angle the preview in axis doesn't change.
do i need to set a G or M code to make it work?
Fusion is generating the gcode from the same parameters in CAM so do I even need to set up linux tool table other than offsets?
- raglanlittlejohn
- Thank you received: 9
23 Oct 2017 06:17 #100651
by raglanlittlejohn
Replied by raglanlittlejohn on topic tool orientation not changing
When I tried 30 and -30 for front/back angle it worked. Not sure if thats the correct order.
23 Oct 2017 12:42 #100671
by Ross77
Replied by Ross77 on topic tool orientation not changing
Did it show the change in axis?
I can enter the values but not sure it is having any effect
- raglanlittlejohn
23 Oct 2017 17:39 #100688
by raglanlittlejohn
I did front angle -30 back angle-30 orient 7. This shows in axis. I just did File, Edit tool table. Add a tool number, and POC number. I also put 3 in DIAM. After saving the tool appears in axis if called in MDI eg T4 M6.
24 Oct 2017 23:35 #100763
Replied by andypugh on topic tool orientation not changing
Front Angle and Back angle are not currently used for anything other than a visual confirmation in the Axis preview.
If and when we get the G71 / G72 codes integrated, then we will use the angles properly.
25 Oct 2017 20:56 #100815
by Ross77
Thanks Andy
So I only need to worry about the offsets then?
Is there any reason why its not even changing the visual in axis when the angles and tool orientation are set?
26 Oct 2017 01:23 - 26 Oct 2017 01:23 #100823
Are you issuing a G43 command?
(by default you need to, but if you don't want to have to there are options)
Last edit: 26 Oct 2017 01:23 by andypugh.
28 Oct 2017 20:49 #100955
by Ross77
Yes G43 for tool offsets when the tool is loaded. its not too much of a issue as it seems to be cutting ok. Just saw in the set up section that it should show in the preview so wondered if I had done something wrong. cheers
30 Oct 2017 23:47 #101035
Maybe you have the front and back angles the wrong way round? (So that the tool has a negative included angle)?
Moderators: piasdom
