Boxford 250F options?
I have just bought a Boxford 250 which is running on a Fanuc OT system and looking for options.
Ultimatly I would like to have the touch screen and run the macros for quick turing etc. and have spindle indexing with live tooling so a retro fit would be the best long term option but I really need to get this up and running asap and then convert in a few months.
option 1
Is it possible to connect to the Fanuc system so I can use Lcnc to control it?
Option 2
Reuse the Fanuc motors with a Granite devices argon and Lcnc
Option 3
Complete refit with new AC servos and drives?
Thanks in advance
- Thank you received: 5982
It was more the possible integration with Fanuc or to reuse some of the fanuc parts.
I believe Jon Elson make some hardware solutions for running Fanuc motors.
Bottom of this list: pico-systems.com/motion.html
It would be good to pick your brains on the conversion Although I don't have the slotted disc on the ball screws and the spindle encoder is a belt driven unit. did you have the stepper drive for the tool station? There seems to be a lot of wiring in the back panel just for that.
Given the Fanuc system is 30 years old I'm leaning away from reusing it.
option 1
No, that would be two motion controllers, who would be in charge?
You missed out option 1.5, keep the Fanuc drives and motors but control them with LinuxCNC.Option 2
Seems like a waste of some good motors and drive hardware.Option 3
With option 1.5 i wouldn't I still need 415v 3 phase supply to run though? can that be done then? Most people seem to think that it is a nightmare to do. I'd be interested if it can be done.
the Fanuc system is nearly 30 years old though, 1990.
Thanks Andy
With option 1.5 i wouldn't I still need 415v 3 phase supply to run though?.
Possibly, but the drives might well be 240V input, or might work perfectly OK on 240V.
How can I find out? Is it just a case of wiring up one of the phases to 240v
