Gildemeister NEF 480 Retrofit
11 Jul 2021 20:02 - 12 Jul 2021 08:50 #214315
by anfänger
Replied by anfänger on topic Gildemeister NEF 480 Retrofit
Thanks spindle and gears are working now
Now it’s time to tune everything and take the first cut.
Last edit: 12 Jul 2021 08:50 by anfänger.
14 Jul 2021 08:18 - 14 Jul 2021 08:21 #214688
by anfänger
Added some new features for the gearchange yesterday, but the rain kept me from testing it.
Now I have buttons for each gear / spindle speed range.
When presse a custom MCode is executed, which stops the spindle and brings up a dialogue with the leaver positions.
Then sets the right clutch und spindle speed.
I think this will come in useful.
But what should be a quick session took me a lot longer than planned as always with me when I try to code I don‘t do it regularly and forget quite quick.
What is still missing is too write spindle speed and gear to a persistent parameter and reload it when powered on again.
Is there a best practice which parameters to use?
Next is to find a way to implement this in the post processor
OK and testing I hope I find the time for testing this evening
Thanks for reading
Patrick
Thanks for reading
Patrick
Last edit: 14 Jul 2021 08:21 by anfänger.
14 Jul 2021 20:25 #214774
by anfänger
made sone progress on the gearbox change today.
Three problem I've got.
First the the spindle sounds like it needs new bearings,
second the parameter #<_spindle_on> os 0 even when the spindle is running, so the spindle doesn't restart after gear change
third the MCode to load the stored gear (M245) doesn't work when I put it in the startup codes. then linuxcnc errors our with M144 unknown.
M144 is a bash script and nit mapped in the INI.
When I run it in MDI later it works fine M144 is the script which brings the popup window wit the gear settings.
Thaks Patrick
Thaks Patrick
16 Jul 2021 06:31 #214992
by anfänger
Fixed the spindle start by reading the hal pins. Now it works, But I didn’t make a video.
What I did film was the successful homing:
Then I removed Chuck and the mechanical clamping device.
I will clean the spindle and then start to prepare for mounting a normal chuck.
The Schunk Cuck and the clamping thing will get a a cleaning and the n will be stored till I have a need for it.
- Thank you received: 5972
16 Jul 2021 12:00 #215026
Replied by tommylight on topic Gildemeister NEF 480 Retrofit
I wonder if that chuck would fit my Mazak Micro Slant 15 ???
16 Jul 2021 12:08 - 16 Jul 2021 12:24 #215028
by anfänger
What kind of Spindle Node do you have? And where her you from?
But I am not sure If I will sell it.
Now that I know how to mount it and if I make some tools mounting and dismounting won’t take that long.
It is a nice three jaw chuck and I have a lot of jaws for it.
But I font think I will ever need the automatic clamping it was fun to get it running and it nice for a Job shop but for me it is more or less useless, cause I don’t think I will make more thank three same parts in a row.
But I would would be really tempted trade it for a 250mm there jaw chuck with two piece jaws cable of 2250 rpm
Last edit: 16 Jul 2021 12:24 by anfänger.
16 Jul 2021 12:23 #215034
No idea on the spindle node.
I am in Kosovo.
No worries, i will keep searching for it, in the mean time i might also use a normal chuck, when i get to retrofit it, the Mesa boards i have for it age getting a bit moldy waiting ...
I am in Kosovo.
16 Jul 2021 12:28 #215037
by anfänger
It’s not really near by, good look on the search.
17 Jul 2021 20:41 #215170
by anfänger
put the tool mount back on the lathe:
then I took the first cut on the machine:
used the hand wheels to tale the first gut of the face plate
After adjusting the spindle speed the surface finish got better. And I should close the cable ways and make me son wipers.
so here it is ready for drilling the faceplate for the new chuck
looks a lit lost, bu should be enough for most of what's coming next time
The following user(s) said Thank You: RotarySMP, tommylight
18 Jul 2021 07:18 #215208
by RotarySMP
Replied by RotarySMP on topic Gildemeister NEF 480 Retrofit
It is a cool feeling to make a part on the machine for the first time. You are way ahead of me
Mark.
Mark.
Moderators: piasdom
Time to create page: 0.250 seconds
