Gildemeister NEF 480 Retrofit
18 Jul 2021 16:43 #215238
by anfänger
Replied by anfänger on topic Gildemeister NEF 480 Retrofit
Yes but I stared before you I guess and don't go into such detail as you.
pus some more sheet metal on the lathe:
and got some left overs one I have no idea where it came from, the other doesn't fit cause of the new servos.
But there is so much left to do. make new wipers, a protection for the panel, route the coolant, close the panel. and finish setting up linuxcnc.
But it "works" now, I can run code, it switches gears, and remembers the one on power down and resets it on start.
the rest is fine tune and make it more convenient to use.
The following user(s) said Thank You: RotarySMP, tommylight
24 Jul 2021 19:59 #215803
by anfänger
I might have found a solution to replace the disintegrated way wipers. One was still ok so I used them and it’s holder as a reference to redraw all the missing ones.
And right now the printer is working on a set of new wipers. I use a 98a shore filament. It feels a bit more flexible. But I think this should be ok. I will give them a try soon
25 Jul 2021 12:14 #215850
by anfänger
So today I put my 3d printed wipers to a test:
I can't see a difference to the only old wiper in performance. SO now time will tell how they work. When they will be replaced I will make some changes to the lip design, but for now they are working.
While I was on the machine I covered the cables of the cross sled
And there was the issue with the Multifix. the old dowels were sheared of and now replacement has arrived.
but with the dowel the misalignment of the main stud needed to be addressed. After some failed tries to do it by hand. I thought when the machine bended the stud... maybe I jan use it to straighten it:
Now its al properly tightened and true.
the spiral is missing, maybe I print something too
25 Jul 2021 14:03 #215855
by anfänger
27 Jul 2021 07:10 #216022
by RotarySMP
Replied by RotarySMP on topic Gildemeister NEF 480 Retrofit
Those 3D printed way wipers look great. Will be interesting to see how they hold up.
Mark
Mark
27 Jul 2021 10:13 #216027
by anfänger
Even if they don‘t least as long as the original ones, the cost is less than 1€ in Filament should be no problem to swap them once a year.
If you need some I can print you a set for testing if you send me a 3d filel.
01 Aug 2021 09:26 #216587
by anfänger
02 Aug 2021 07:35 #216668
by anfänger
Now with a keyboard tray out of some leftovers from the old interior of the control cabinet
And here a video of me try fo figure out If I should find a way to couple the enclosure withe the console.
not sure how to do it, I was thinking about a switchable magnet or so or at least something the easily breaks away when the enclosure gets stuck
09 Aug 2021 20:48 #217343
by ChrisMpa
Replied by ChrisMpa on topic Gildemeister NEF 480 Retrofit
hello. just yesterday i got mine gildemeister nef 480 fanuc. is it possible to send me any manual related to thiw machine? have you try to use the lathe before the linuxcnc retrofit? the person that sold it to you knew about this lathe?any help is more than axeptable
10 Aug 2021 07:17 #217379
by anfänger
Hi I have some documentation and all scanned, I can share with you if you like, but it’s all in German.
I never plugged the machine in before retrofitting and it was the plan from the beginning, so I didn’t ask much about the machine.
Moderators: piasdom
Time to create page: 0.098 seconds
