Gildemeister NEF 480 Retrofit
27 Feb 2021 21:44 #200353
by chris@cnc
Replied by chris@cnc on topic Gildemeister NEF 480 Retrofit
Hi Patrick,
there is a chamber in the valve. when the pump is running it makes the chamber full of oil and builds up pressure. if the pressure is reached = chamber full. no pressure = chamber leaking. When the pump stops, the chamber slowly opens and oil drips into the line. Takes a little longer. If the chamber does not open it is clogged. You can open the chamber but carefully. There are very small parts in.
Chris
Chris
27 Feb 2021 21:53 - 27 Feb 2021 21:56 #200354
by db1981
Replied by db1981 on topic Gildemeister NEF 480 Retrofit
zum übersetzen ist jetzt zu spät für mich....
Such mal nach SKF Monoflex, da gibts ein dickes pdf und schaue dir mal den Teil mit den Nachschmierverteilern an. Ich weiß nicht 100% ob das bei der Kiste so ist, könnte aber sein. Kenne ein paar alte Bohrmaschinen mit dem Zeugs.
d.h. Pumpe muss laufen bis Druck aufgebaut ist (Druckschalter links) -> Pumpe aus -> Schmierzyklus erfolgt...
Last edit: 27 Feb 2021 21:56 by db1981. Reason: deutsch hängt auch, können wir in C schreiben
28 Feb 2021 04:23 - 28 Feb 2021 05:48 #200369
by sivaraj
Replied by sivaraj on topic Gildemeister NEF 480 Retrofit
Usually lub system will have metering valve or piston valve on each line.
Your lube system includes pressure switch and Based on photo I assume your lube system uses piston oil distributor.
Lub Pump has to run till pressure build up , once pressure switch operates (usually around 10-15 bar), then hold 2or3 sec more then switch off the Lube pump .
After lub pump goes off piston distributor will work and push output few drops of oil .
Usually there will be a punched value on each piston distributor (brass material) which shows rate of oil output like 2cc
You need to disconnect all nylon outlet tubes and simulate the sequence to check piston distributor .
Since you do not have automatic control now you need do it manually .
While pump running if any distributor has continuous oil flow means it is a defective
You should see drops of oil coming out from the piston distributor each time while pump goes of after the pressure build up .
There will not be oil flow while pump running .
piston valve ejects oil only if pressure builds up and then input pressure goes down due to pump goes off .
Hope this helps
Hope this helps
Last edit: 28 Feb 2021 05:48 by sivaraj.
28 Feb 2021 09:11 - 28 Feb 2021 11:05 #200381
by anfänger
Replied by anfänger on topic Gildemeister NEF 480 Retrofit
Thanks all of you. This helps a lot. I think I trashed one of the valves then. I thin when I shot it out I lost a seal or something. I will have a look today but I am not very confident to find it. So its hinting for spare parts then. With the hint from db1981 I found the part number I need (995-994-110) now I just need to find a source that sells to privateers. And patiently bleed the system.
Thanks everyone!
Thanks everyone!
Last edit: 28 Feb 2021 11:05 by anfänger.
28 Feb 2021 13:08 #200403
by scotth
Replied by scotth on topic Gildemeister NEF 480 Retrofit
The following user(s) said Thank You: J Green
28 Feb 2021 13:29 #200410
by db1981
try here :
www.schmieranlagen.com
maybe the parts numbers have changed over the years, but i'm shure they can help you.
28 Feb 2021 13:51 #200417
by anfänger
they are still the same. Many thanks! I ordered 13 just in case
28 Feb 2021 15:48 #200426
by J Green
Replied by J Green on topic Gildemeister NEF 480 Retrofit
anfanger
Thank's for describing your shop , sounds like it is really spacious an useful .I am envious
scotth & db1981 ---- Have been looking for that information about the Oil an distribution parts for some time . Thanks for sharing the information ,it is a big help to me and others having DMG machines .
Bob
Bob
01 Mar 2021 07:17 #200509
by anfänger
While waiting for the spare parts for the oiling system I continued to assemble the lathe. If I need to change some lines on the oil system this will backfire, but I wanted to make some progress.
So I cleaned the switches and prepared them for wireing:
I also cleaned off some welded parts on the panel
Still need to think of a neat way to cover the holes. Then I gave the cover for the old control interface a test:
With a bit of straightening this should fit nicely. And I prepared the wire terminals in the console:
Now it‘s waiting for some more spare parts and continue to wire everything up.
01 Mar 2021 07:38 #200511
by anfänger
Talking about backfire. After I posted this I realised I need to reinstall the retainers the prevent the carriage from lifting. And I am pretty sure with the console in place I won‘t be able to tighten the screws...
Moderators: piasdom
Time to create page: 0.283 seconds
