Gildemeister NEF 480 Retrofit
02 Mar 2021 22:29 #200838
Replied by andypugh on topic Gildemeister NEF 480 Retrofit
Too late, but there are some relatively cheap indent crimpers on eBay / Amazon that can do those terminals.
I have ended up with two, one for the little pins in Lemo connectors and one for the M23 connectors.
www.ebay.co.uk/itm/261243781537
As an example.
As an example.
03 Mar 2021 17:07 #200912
by JimPanski
Replied by JimPanski on topic Gildemeister NEF 480 Retrofit
Hi Andy,
may I ask wich one you are using for the M23 connector pins?
03 Mar 2021 17:51 #200917
I am using this particular one:
www.amazon.co.uk/gp/product/B007G5QAVU/r...=ATYMR08ODFL16&psc=1
The following user(s) said Thank You: JimPanski
05 Mar 2021 22:24 #201139
by anfänger
Replied by anfänger on topic Gildemeister NEF 480 Retrofit
07 Mar 2021 19:15 #201331
by anfänger
not much progress since Friday. It's cold in the shop.
I remounted the first limit switch on the carriage. The second needs a lite mit more care
So I took a look at the cabinet an realized that the cables from the connectors weren't numbered, So skipped the idea of connecting them directly and Gabe them an extra wiring terminal.
Not yet finished but enough for today.
- Thank you received: 5972
07 Mar 2021 21:08 #201358
Replied by tommylight on topic Gildemeister NEF 480 Retrofit
Very nice progress, despite the cold.
It was sunny today so also got some work done, but the moment the sun went over the mountains it got very cold !
08 Mar 2021 08:00 #201395
by anfänger
You know it’s cold when you need a hear gun to warm up the rubber seals to be able to get the cable trough.
I am looking forward to a bit warmer weather.
08 Mar 2021 08:53 #201399
by J Green
Replied by J Green on topic Gildemeister NEF 480 Retrofit
Seems as if the cold bothers me more the older I get .
To heat soak equipment , used to make 3/4 inch electrical tube frame and cover it with plastic 50mil thick building foil wrap . Was cheap and easy to drape over the temporary metal tube frame . Added electric heater and a fan . Can also be used for spray painting booth .
When it's freezing don't lick flag poles
Bob
Bob
08 Mar 2021 09:42 #201406
Last two winters were mild here so not much of pole licking going on.
08 Mar 2021 09:52 - 08 Mar 2021 09:53 #201407
by anfänger
The mean thin is thee weeks ago we hat -10° two weeks ago 18° So now I think it should be warm when it’s sunny outside but it is 0°.
And I am getting old and start complaining about everything...
Last edit: 08 Mar 2021 09:53 by anfänger.
Moderators: piasdom
