Spindle synchronized motion without starting the spindle
06 Sep 2021 12:45 #219755
by anfänger
Spindle synchronized motion without starting the spindle was created by anfänger
Hi, I have a question is it possible to use spindle synchronized motion without starting the spindle?
The reason is, I want to use it to tap internal threads by manually turning the chuck.
Cause I am not sure if tapping would work wit the ramp of my spindle an so overshoot and crash the tap on the bottom of the hole.
Thanks Patrick
Thanks Patrick
- Thank you received: 5942
06 Sep 2021 13:07 #219756
Replied by tommylight on topic Spindle synchronized motion without starting the spindle
I am pretty sure it is possible, seen someone on youtube doing just that, turning the chuck by hand and the rest of the machine following it.
06 Sep 2021 14:16 #219761
Replied by andypugh on topic Spindle synchronized motion without starting the spindle
Spindle-synch will refuse to start if the spindle is not on and set to non-zero speed.
So one work-around is to set the spindle-override to zero and then command a spindle speed / start.
06 Sep 2021 14:23 #219762
Replied by PCW on topic Spindle synchronized motion without starting the spindle
06 Sep 2021 14:23 #219763
by anfänger
Replied by anfänger on topic Spindle synchronized motion without starting the spindle
Thanks, I will give it a try
06 Sep 2021 19:45 #219782
by anfänger
It works, now just a gcode to set the spindle override to 0 and back. I also tested the rigid tapping and even in low gear I overshoot 6 mm so for tapping I need to do it manually. Till I find another solution.
Many thanks for the help.
Cheers Patrick
Cheers Patrick
12 Sep 2021 10:44 #220285
This might be something that you can configure in the spindle drive. A braking resistor might be needed.I also tested the rigid tapping and even in low gear I overshoot 6 mm
Moderators: piasdom
Time to create page: 0.136 seconds
