Small victory in the war against the Cincinnati cinturn 12u
- smc.collins
- Thank you received: 109
29 Nov 2022 18:03 #258003
by smc.collins
Replied by smc.collins on topic Small victory in the war against the Cincinnati cinturn 12u
I'll try g4 again if this doesn't work, but my hold is supposed to start after the digital parameter goes low, then it goes to lock the carousel
- smc.collins
01 Dec 2022 00:16 - 01 Dec 2022 00:26 #258173
by smc.collins
still not working, had to post from the Lathe, what I do know, is that something is causing a abort after reaching the desired pocket, and at that point, it will not execute any further. these 2 files are directly from the machine
ngc
o<toolchange> sub
; only unload the tool if there is a tool in the spindle
; This assumes that the carousel is already aligned correctly.
; It is important to unload the tool before shutting down the machine.
G53 G0 X16.00
O100 IF [#<selected_tool> GT 0]
M65 P1 ; unlock carousel
M66 P1 L4 Q1 ; wait for locked=false
O106 if [#5399 LT 0]
(abort, failed to unlock carousel)
O106 endif
M68 E0 Q#<selected_pocket> ;set the carousel to move to the right pocket
M64 P0 ; start carousel <--- dies here once the pocket is reached, all code execution ends
everything after start carousel is being ignored ??????
M66 P0 L3 Q60 ; wait for carousel finished
O107 if [#5399 LT 0]
(abort, failed to align carousel)
O107 endif
M65 P0; stop carousel
M64 P1 ; lock carousel
M66 P1 L3 Q1 ; wait for locked=true
O108 if [#5399 LT 0]
(abort, failed to lock carousel)
O108 endif
O100 ENDIF
o<toolchange> endsub [1]
M2
attaching hal to look for obvious errors.
hal
loadrt carousel pockets=6 dir=1 encoding=bcd num_sense=3 parity=0
loadrt conv_float_s32
addf carousel.0 servo-thread
addf conv-float-s32.0 servo-thread # G-code analogue outputs are float-type
net car-enable motion.digital-out-00 carousel.0.enable
net car-ready carousel.0.ready motion.digital-in-00
net car-fwd carousel.0.motor-fwd
net car-lock carousel.0.active
net car-pos-req motion.analog-out-00 conv-float-s32.0.in
net car-pos-s32 conv-float-s32.0.out carousel.0.pocket-number
#assign locked pin
net car-locked <= hm2_5i25.0.7i77.0.0.input-00
#assign to turret unclamp relay
net car-lock => hm2_5i25.0.7i77.0.0.output-05
#assign to turret rotate motor relay
net car-fwd => hm2_5i25.0.7i77.0.0.output-08
#digital inputs assign BCD switches
net bit0 carousel.0.sense-0 <= hm2_5i25.0.7i77.0.0.input-04
net bit1 carousel.0.sense-1 <= hm2_5i25.0.7i77.0.0.input-05
net bit2 carousel.0.sense-2 <= hm2_5i25.0.7i77.0.0.input-06
#Strobe input, sinals when turret is aligned with pocket to lock assign to Strobe switch
net carousel.0.1 carousel.0.strobe
net carousel.0.1 <= hm2_5i25.0.7i77.0.0.input-03
#net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared <--- if I uncomment this line, I get a signal already connected to t-loop fault at startup
net tool-change-loop iocontrol.0.tool-change iocontrol.0.tool-changed
loadusr sim_pin carousel.0.jog-fwd
ngc
o<toolchange> sub
G53 G0 X16.00
O106 endif
O107 endif
O108 endif
O100 ENDIF
M2
hal
#assign locked pin
Last edit: 01 Dec 2022 00:26 by smc.collins.
- smc.collins
01 Dec 2022 02:23 - 01 Dec 2022 02:25 #258179
by smc.collins
I did a quick cleanup of my hal file to make it more legible, it appears to be identical except for some IO to my working sim file now.
Last edit: 01 Dec 2022 02:25 by smc.collins.
01 Dec 2022 08:45 #258194
by mgm
Replied by mgm on topic Small victory in the war against the Cincinnati cinturn 12u
I am currently also busy with my carousel
This is my post:
forum.linuxcnc.org/10-advanced-configura...f-a-carousel-changer
I attach you my working hal!
This is my post:
The following user(s) said Thank You: smc.collins
01 Dec 2022 14:47 - 01 Dec 2022 14:49 #258213
Which of the abort messages is it showing when it aborts?
Replied by andypugh on topic Small victory in the war against the Cincinnati cinturn 12u
Last edit: 01 Dec 2022 14:49 by andypugh.
01 Dec 2022 14:53 #258214
Open a halmeter and see if motion.digital-in-00 goes true.
Repeat for all the other inputs and outputs. Which one isn't doing what it should?
The main question is, does carousel.0.ready go true when the carousel is in the right place?
- smc.collins
01 Dec 2022 15:26 #258219
by smc.collins
will do tonight, there are no error messages other than failed to lock carousel, which is obvious, because there isn't a pause for the mechanism to settle and align.
other than this issue of it failing at some point it does work, but it's not working properly.
i will do a hal scope recording of the requested parameters and post it here later. at work, maybe in 5-6 hrs.
back to the 997 turbo for now tt
01 Dec 2022 15:48 #258223
That must mean that it is getting to here, if that is the message:
So it isn't getting a "locked" signal on motion.digital-in-01. Which seems likely as it is not connected in HAL as far as I can see.
O108 endif
- smc.collins
01 Dec 2022 22:42 - 01 Dec 2022 22:45 #258266
by smc.collins
It ignores all of my attempts to pause the lock cycle, all of them.
add
#Carousel Ready
net car-ready <= hm2_5i25.0.7i77.0.0.input-01-not # this switch will be open when the carousel is locked
this will be the hal file after this change
loadrt conv_float_s32 #(Already loaded in sim_vmc.hal)
#Signal Connections to Hal Components
net carousel.0.strobe carousel.0.in
#Digital inputs
net carousel.0.in <= hm2_5i25.0.7i77.0.0.input-03
#Carousel Ready
#assign locked pin
add
#Carousel Ready
#Digital inputs
#Carousel Ready
#assign locked pin
Last edit: 01 Dec 2022 22:45 by smc.collins.
01 Dec 2022 23:54 #258273
I think that your G-code is still waiting for a carousel-locked signal on motion.digital-in-01 and there is nothing related to that in the HAL.
Moderators: piasdom
