Small victory in the war against the Cincinnati cinturn 12u
08 Dec 2022 01:05 #258859
(at least for the type of BCD that carousel understands)
Replied by andypugh on topic Small victory in the war against the Cincinnati cinturn 12u
For numbers < 10 BCD and binary are identical.that matches my documentation. so set it to binary in the hal ?
- smc.collins
- Thank you received: 109
08 Dec 2022 01:23 #258862
by smc.collins
Replied by smc.collins on topic Small victory in the war against the Cincinnati cinturn 12u
well, then there is a problem, because I am getting carousel failure to align errors. and the position of the turret is random. I'm open to suggestion on remedy's, but I need a bit of hep in the how to debug department. running my generator to spin the turret is getting expensive
08 Dec 2022 01:44 #258863
I assume that RANDOM_TOOLCHANGER isn't in the INI?
(This isn't a joke, much as it might look like one)
What is the exact error message? Is it from your NGC file? Which line of the NGC file?
Halscope the strobe and the carousel.0.current-position (along with ready and motor-fwd). Also, to be sure, carousel.0.pocket-number to check that is being correctly set.
- smc.collins
08 Dec 2022 02:31 #258867
by smc.collins
No, I checked all of the files in the machine, and nowhere, even using search can i find RANDOM_TOOLCHANGER.
the error message is from my NGC file afaict, I just get a warning in axis,
failed to align carousel
I can do the scope tests tomorrow, how do I check the carousel.0.pocket number ? against what ? or to verify it with ? I can scope it and screen shot it tomorrow.
on a good note, the rest of the functions appear to be correct. I can grab the files off the Lathe and post them tomorrow afternoon
08 Dec 2022 16:48 - 08 Dec 2022 16:48 #258899
OK, this is from your NGC routine and is if the wait-on-input for carousel-ready fails.
This could be because the carousel never believes itself to be at the correct position. Which could be either because it is reading the position incorrectly, or because the M6 (or T) command is picking a pocket > 6 or < 1.
Against the selected pocket number. Which should be the pocket number from the tool table of the tool you have chosen when starting the tool change.I can do the scope tests tomorrow, how do I check the carousel.0.pocket number ? against what ?
Last edit: 08 Dec 2022 16:48 by andypugh.
The following user(s) said Thank You: smc.collins
- smc.collins
08 Dec 2022 22:33 - 08 Dec 2022 23:01 #258919
by smc.collins
screen shots from scope, I am not sure about the behavior of Tloop, it just goes up 1 div and then drops right down, as if it is basically just sending a triggering signal. the car-pos-32 seems to be working at it is reporting position properly. So this looks like a issue with Tloop. I attached my hal files.
this is currently in my main cinturn12u.hal I assume this is the problem
net T-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
whereas this is commented out in my toolchangerBCD.hal
#net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared
So is it safe to assume that this needs to be edited to and placed in either my main cintrun12u.hal or my toolchangerbcd.hal. I'd prefer to use the later if it makes no difference, because then ALL of my toolchange config exists outside of my primary hal file. Also, my brain is very smooth today, I hate german car engineers sometimes, I wish they would buy their electrical systems from GM and or Delphi
Last edit: 08 Dec 2022 23:01 by smc.collins.
- smc.collins
08 Dec 2022 22:41 #258921
by smc.collins
- smc.collins
08 Dec 2022 23:08 #258927
by smc.collins
MGM attached his carousel file and I find myself confused about the behavior of the t loop now
this is in his file. it appears he might have a turret of some sort like mine
#net tool-change-finished carousel.0.ready => iocontrol.0.tool-changed
#net tool-change-loop iocontrol.0.tool-change iocontrol.0.tool-changed
#net start-tool-change iocontrol.0.tool-change => carousel.0.enable
09 Dec 2022 00:02 #258940
This ought to work, but is a bit inconsistent in format:
Could be
net carousel.0.in carousel.0.strobe
net car-locked motion.digital-in-01
net car-lock motion.digital-out-01
#Digital inputs
net bit0 carousel.0.sense-0 <= hm2_5i25.0.7i77.0.0.input-04
net bit1 carousel.0.sense-1 <= hm2_5i25.0.7i77.0.0.input-05
net bit2 carousel.0.sense-2 <= hm2_5i25.0.7i77.0.0.input-06
net carousel.0.in <= hm2_5i25.0.7i77.0.0.input-03
Could be
#Digital inputs
net strobe carousel.0.strobe <= hm2_5i25.0.7i77.0.0.input-03
09 Dec 2022 00:12 #258942
I don't think that T-loop is a major problem.
Personally I would leave the changer in the middle of that loop, so that "change" starts the process and "changed" is signalled at the end, but doing it your way does mean that the system can do other things while waiting for the carousel. (of course you might not want to do that...)
But, you you don't seem to have logged the channels I asked for.
carousel.0.strobe
carousel.0.ready
carousel.0.motor-fwd
carousel.0.strobe
carousel.0.ready
Moderators: piasdom
Time to create page: 0.176 seconds
