7I73 Pendant/control panel interface
21 May 2012 11:28 #20243
by marv-t
7I73 Pendant/control panel interface was created by marv-t
Hello!
I use 2x4i65 with 2x7i33TA and 2x7i37TA. Now I would use the 7i73 via 7i44.
Is it possible to combine these cards together? Is there a firmware to access the 7i73?
I have seen it is possible with a 7i25 but not with a 7i65.
After your OK, I will buy these Cards.
Thanks and have a nice day,
Thomas
Thomas
21 May 2012 13:43 - 21 May 2012 13:53 #20249
Replied by PCW on topic Re:7I73 Pendant/control panel interface
It should be possible but would require new firmware.
What current firmware are you using?
Last edit: 21 May 2012 13:53 by PCW. Reason: clarify
21 May 2012 14:35 #20251
by marv-t
Replied by marv-t on topic Re:7I73 Pendant/control panel interface
Hi!
I use the firmware SVST8_4.BIT comes with 2.5.
Thanks a lot,
Thomas
Thanks a lot,
Thomas
21 May 2012 15:51 #20257
OK do you current have both 7I33s connected to one 4I65?
and do you use any stepgens?
I am asking so I can figure out what is the least disruptive way to add the sserial support to your current boards (the 4I65 has a fairly small FPGA so I am limited in what I can cram into it)
If you are using a 7I33 per 4I65 and no stepgens then a SVSS4_8 config on one or both cards (4 servo + 8 sserial channels) is probably a workable solution
21 May 2012 16:07 #20258
by marv-t
I have 1x7i33 and 1x7i37 on each 4i65.
I have not stepgens configured on the boards only the I/Os(7i37) are in use.
My favorite configuration:
4i65 0: 7i33 - 7i44 - 7i37
4i65 1: 7i33 - x - 7I37
21 May 2012 17:11 #20261
OK so theres a pinout for this config (SVSS4_8) with one small change: its 7I33,7I37,7I44.
That is, the smart serial is on the last connector. I'll built s 4I65 version of this config sometime today or tommorow
22 May 2012 23:10 #20276
ok 4i65 svss4_8 is available from freeby.mesanet.com/4i65_svss4_8.zip
23 May 2012 06:54 #20279
by marv-t
Hi!
Thanks a lot. Now I order the 7i44 and 2x 7i73.
Have a nice day,
Thomas
Have a nice day,
Thomas
02 Dec 2012 00:16 #27116
by marv-t
Replied by marv-t on topic 7I73 Pendant/control panel interface
Hello!
After a long time I tried the new Firmware, but now I have some troubles.
The output from dmesg:
[ 210.607524] hm2: loading Mesa HostMot2 driver version 0.15
[ 210.609248] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 210.609269] hm2_pci: discovered 4i65 at 0000:04:00.0
[ 210.609313] hm2_4i65.0: firmware: requesting hm2/4i65/SVSS4_8.BIT
[ 210.935897] hm2/hm2_4i65.0: inconsistent Module Descriptor for Smart Serial Interface, not loading driver
[ 210.935900] hm2/hm2_4i65.0: Version = 0, expected 0
[ 210.935903] hm2/hm2_4i65.0: NumRegisters = 6, expected 6
[ 210.935905] hm2/hm2_4i65.0: InstanceStride = 0x00000010, expected 0x00000040
[ 210.935908] hm2/hm2_4i65.0: MultipleRegisters = 0x0000003C, expected 0x0000003C
[ 210.935910] hm2/hm2_4i65.0: inconsistent Module Descriptor!
[ 210.935913] hm2/hm2_4i65.0: failed to parse Module Descriptor 4
[ 210.935917] hm2_4i65.0: board fails HM2 registration
[ 210.935924] hm2_pci: probe of 0000:04:00.0 failed with error -22
[ 211.148731] hm2: unloading
Is there anywhere sample configuration with the 7i73.
Have a nice evening,
Thomas
Thomas
02 Dec 2012 00:41 - 02 Dec 2012 00:41 #27117
Replied by PCW on topic 7I73 Pendant/control panel interface
Oops sorry, thats my fault.
I'll make a new bitfile with that fixed
but it may have to wait till Monday if
I'm not around work anytime this weekend.
Last edit: 02 Dec 2012 00:41 by PCW.
