7I73 Pendant/control panel interface
04 Dec 2012 07:55 #27165
Replied by PCW on topic 7I73 Pendant/control panel interface
OK _correct_ 4i65 svss4_8 is available from freeby.mesanet.com/4i65_svss4_8.zip
The following user(s) said Thank You: marv-t
07 Dec 2012 01:46 #27325
by marv-t
Replied by marv-t on topic 7I73 Pendant/control panel interface
Hello!
Now the 7i73 is working. I connected a MPG and it works properly.
Only one question left: How can I access the analog input( IN 0..3)?
This is very helpfully for spindle and feed overwrite,
Thanks a lot for the corrected firmware.
Thomas
Thomas
07 Dec 2012 02:01 - 07 Dec 2012 02:16 #27329
To read the analog inputs, you need to set the 7I73s mode to 1 or 2
that is include:
sserial_port_0=1xxxxxxx in the config line
(assuming the 7I73 was on channel 0)
that is include:
Last edit: 07 Dec 2012 02:16 by PCW.
07 Dec 2012 02:32 #27334
by marv-t
Thank you very much!
Now I know how to setup the sserial cards.
Thomas
Thomas
07 Dec 2012 02:36 #27335
BTW, This information is in the (very large) hostmot2 man page
- hardware_crash
23 Mar 2024 13:04 - 23 Mar 2024 13:05 #296575
by hardware_crash
Replied by hardware_crash on topic 7I73 Pendant/control panel interface
Hello Peter,
I know this is a very old post, but I had to setup a new pc for my machine which used the 4i65_svss4_8.bit file and the download (freeby.mesanet.com/4i65_svss4_8.zip ) seems to be unavailable.
Any chance you could reupload the 4i65_svss4_8.bit file?
Thanks in advance
Thanks in advance
Last edit: 23 Mar 2024 13:05 by hardware_crash.
23 Mar 2024 14:54 #296579
- hardware_crash
23 Mar 2024 15:54 - 23 Mar 2024 15:59 #296582
by hardware_crash
Thank you for the fast response.
It seems that I have a similar error as marv-t had before:
SSerial is the same as in my old config: sserial_port_0=00000000
dmesg output:
dmesg output:
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 4i65 at 0000:02:00.0
hm2/hm2_4i65.0: Low Level init 0.15
hm2/hm2_4i65.0: inconsistent Module Descriptor for Smart Serial Interface, not loading driver
hm2/hm2_4i65.0: Version = 0, expected 0
hm2/hm2_4i65.0: NumRegisters = 6, expected 6
hm2/hm2_4i65.0: InstanceStride = 0x00000010, expected 0x00000040
hm2/hm2_4i65.0: MultipleRegisters = 0x0000003C, expected 0x0000003C
hm2/hm2_4i65.0: inconsistent Module Descriptor!
hm2/hm2_4i65.0: failed to parse Module Descriptor 4
hm2_4i65.0: board fails HM2 registration
RTAPI_PCI: Unmapped 65536 bytes at 0x7f7f4d583000
Driver probe function failed!
hm2_pci: error registering PCI driver
hm2_pci: rtapi_app_main: Operation not permitted (-1)
Last edit: 23 Mar 2024 15:59 by hardware_crash.
23 Mar 2024 16:16 - 26 Mar 2024 21:47 #296584
OK that must be the same one I have
I'll have to re-make it but that needs an older version of ISE
which I don't have at home so I can only do it Monday at work.
Last edit: 26 Mar 2024 21:47 by PCW.
26 Mar 2024 21:47 #296845
The following user(s) said Thank You: hardware_crash
Time to create page: 0.087 seconds
