7I73 Pendant/control panel interface
- hardware_crash
27 Mar 2024 16:04 #296914
by hardware_crash
Replied by hardware_crash on topic 7I73 Pendant/control panel interface
That worked perfectly, Thank you very much !
When starting the GUI I now get the following messages:
I was searching for instructions how to update the cards but cant find usefull information.
Looks like theres a Tool calles "updatess" but couldnt find that either.
Maybe you have Information on the update procedure?
hm2/hm2_4i65.0: Warning: sserial remote device
7i70 channel 5 has old
firmware that should be updated
7i71 channel 7 has old
27 Mar 2024 19:10 #296933
Replied by PCW on topic 7I73 Pendant/control panel interface
Those must be very old 7I70s,7I71s...
www.mesanet.com/software/parallel/sserial.tgz
has the update information and firmware files.
- hardware_crash
28 Mar 2024 15:25 - 28 Mar 2024 15:28 #297005
by hardware_crash
Thanks for the fast response and the files.
Yes the cards are quite old, I guess I bought them 2013/14.
Looks like theres the next problem with upating the cards.The README states that a version of at least 1.43 is necessary
otherwise the FPGA card firmware needs to be updated first.
sudo mesaflash --device 4i65 --sserial
SSLBP port 0:
SSLBP Version: 1.42
SSLBP Channels: 8
SSLBP Baud Rate: 250000
Last edit: 28 Mar 2024 15:28 by hardware_crash.
28 Mar 2024 16:00 #297009
Akk! I'll update the 4I65 firmware (again...)
The 5I20/4I65 (basically same hardware)
are our oldest LinuxCNC supported cards
And I have not built firmware for them for
maybe 7 -8 years or so
The following user(s) said Thank You: hardware_crash, tommylight
29 Mar 2024 00:08 #297051
- hardware_crash
29 Mar 2024 11:49 #297099
by hardware_crash
Worked Perfectly, Thank you Peter!
Now the cards are updated and the warnings in linuxcnc are gone
Time to create page: 0.099 seconds
