SSI absolute encoders and analog servos
24 Aug 2016 18:37 #79370
by terkaa
Replied by terkaa on topic SSI absolute encoders and analog servos
24 Aug 2016 19:01 #79371
Replied by PCW on topic SSI absolute encoders and analog servos
No, that's the timeout value the timer should be set to read ahead the transmission time (80 usec for 32 bits at 400 KHz)
plus a small margin, so -100 usec should be fine
Can you post all your current SSI related settings here
Also take a look at DPLL phase-error-usec in case there's a locking problem (though I would not expect this)
(it should not ever be greater than you jitter numbers)
24 Aug 2016 19:15 #79373
by terkaa
Related config:
loadrt hm2_pci config="ssi_chan_0=xencoder%32e
#SSI stuff
setp hm2_5i25.0.ssi.00.frequency-khz 400
setp hm2_5i25.0.ssi.00.timer-number 1
setp hm2_5i25.0.dpll.01.timer-us -150
setp hm2_5i25.0.ssi.00.xencoder.scale 10000
Tero
#SSI stuff
Tero
24 Aug 2016 19:28 #79374
Also what LinuxCNC version
25 Aug 2016 04:06 #79395
by terkaa
Recently updated to 2.7.6
25 Aug 2016 07:05 #79397
by terkaa
Also found this from terminal:
Message from syslogd@Cinci at Aug 25 08:54:14 ...
kernel:[ 545.868700] NMI: PCI system error (SERR) for reason a1 on CPU 0.
kernel:[ 545.868707] Dazed and confused, but trying to continue
Related?
Related?
25 Aug 2016 09:46 #79403
Might be related, sounds like a PC hardware error of some kind
25 Aug 2016 10:08 #79404
by terkaa
I believe it is a bug within graphics adapter firmware. Those errors were present before this timing warning
Tero
Tero
25 Aug 2016 10:59 #79407
by terkaa
How can I debug this issue more to find out actual cause for timing warning.
25 Aug 2016 16:19 #79433
I would try to eliminate the NMI, this is not going to be good for real time performance
Also, as I mentioned, you could monitor (via halscope for example) the dpll error so see if it loses sync do to
some real time issue with your system
Time to create page: 0.165 seconds
