Problems using plugin PCI parallel port as main IO.
04 Nov 2016 16:15 #82430
by Mouse
Problems using plugin PCI parallel port as main IO. was created by Mouse
I've had linuxCNC running on a flatbed router for several months however after a PC failure the computer was changed and I can not get Linux CNC to communicate with the plug in PCI parallel port. dmesg and lspci suggest the plug in card is being recognised in at some level in both hardware and operating system however I can't get LinuxCNC to work with it.
Details:
Motherboard has no on-board parallel port.
Plug in PCI parallel card has 9865 chipset in it.
I have tried manually changing the .hal file to the address listed below from lspci with no success.
Any pointers to what I may be doing wrong?
Response from dmesg,
Response from lspci --vv
Details:
awesomearms@debian:~$ dmesg | grep parallel
[ 10.720118] PCI parallel port detected: 14f2:0121, I/O at 0x1008(0x0), IRQ 23
[ 18.703161] ppdev: user-space parallel port driver
06:00.2 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03 [IEEE1284])
Subsystem: Device a000:2000
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B+ DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin C routed to IRQ 23
Region 0: I/O ports at 1008 [size=8]
Region 1: I/O ports at 1000 [size=8]
Region 2: Memory at 90001000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at 90000000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
Kernel driver in use: parport_pc
04 Nov 2016 16:53 - 04 Nov 2016 16:55 #82433
by jmelson
Replied by jmelson on topic Problems using plugin PCI parallel port as main IO.
Is this for software-generated steps? If so, any parport card should work fine. You will have to go into the HAL file and change the port address to either 1000 or 1008, which lspci shows as the ranges of I/O prt addresses.
Ahh, one other thing. Newer parallel ports run on 3.3 V, the old (really old) ports ran on 5V. This could cause some step drivers to not see enough voltage/current to operate. If that is the case, a break out board with voltage boosters will be needed.
Jon
Jon
Last edit: 04 Nov 2016 16:55 by jmelson.
04 Nov 2016 17:03 #82434
by Mouse
I put the address in this line of the .hal file.
Replied by Mouse on topic Problems using plugin PCI parallel port as main IO.
Yes. Step, Direction and limit stops etc...Is this for software-generated steps?
I have tried both 1000 and 1008 as well as converting them to hex 0x3E8 and 0x3F0 and tried those as well but no luck.You will have to go into the HAL file and change the port address to either 1000 or 1008, which lspci shows as the ranges of I/O prt addresses.
loadrt hal_parport cfg="XXXX"
- Thank you received: 1369
04 Nov 2016 17:29 #82435
Replied by Todd Zuercher on topic Problems using plugin PCI parallel port as main IO.
What does this show you?
cat /proc/ioports | grep parport
04 Nov 2016 17:39 #82437
by Mouse
Thanks, I get.
awesomearms@debian:~$ cat /proc/ioports | grep parport
1008-100a : parport0
100b-100f : parport0
04 Nov 2016 17:49 #82438
It looks like you have a 2 port parallel card and addresses should be 0x1008 and 0x100b. You will have to figure out which is which.
Did you say you already tried loadrt hal_parport cfg="0x1008"?
04 Nov 2016 18:12 #82439
by Mouse
0x1008 was unresponsive and 0x100b gave the following error on the Linux CNC error window.
I have also noticed that dmesg has the parallel port at 0x1008 but also on IRQ 23, does this need to also be set?
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_parport.ko: Device or resource busy
./beastatronVFD.hal:6: exit value: 1
./beastatronVFD.hal:6: insmod for hal_parport failed, returned -1
See the output of 'dmesg' for more information.
8861
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
[ 10.720140] parport0: PC-style at 0x1008, irq 23 [PCSPP,TRISTATE,EPP]
04 Nov 2016 18:26 #82440
Reboot and try 0x100b again.
04 Nov 2016 18:39 #82442
by Mouse
Same error as I described above.
I'm off for the weekend but will try out any further suggestions on Monday.
04 Nov 2016 19:13 #82444
Just noticed that both the addresses from your above cat /proc/ioports | grep parport are listed as parport 0. When I use that command on a machine with multiple parallel ports I get this.
Something goofy is going on. Before when you said 0x1008 was "unresponsive" what did you mean? Unresponsive to what?
0378-037a : parport0
e030-e032 : parport2
e050-e052 : parport1
Time to create page: 0.131 seconds
