Hardware & Machines
Driver Boards
Indramat 3TRM2 driver
Thank you received: 5
30 Jan 2023 16:23 - 30 Jan 2023 16:26 #263247
by fogl
All the tests i did were on the machine, with the servo amplifier installed and the motors connected. The servo amplifier was enabled (there is an enable signal).
I used the isolation transformer to power the oscilloscope, to make sure the scope ground was floating. I am not sure this was actually necessary, but i wanted to be sure i don't accidentally ground some of the test points.
Regards
Klemen
Last edit: 30 Jan 2023 16:26 by
fogl.
Hardware & Machines
Driver Boards
