Mesa 7i96 Ethernet board
09 Jul 2017 21:26 #95552
Replied by PCW on topic Mesa 7i96 Ethernet board
Do you have a running (motion works etc) LinuxCNC configuration when
you ran the scripts?
- microsprintbuilder
- Thank you received: 4
09 Jul 2017 21:41 #95555
by microsprintbuilder
Replied by microsprintbuilder on topic Mesa 7i96 Ethernet board
Yes, I have axis running. Inputs are working, haven't checked the steppers yet
09 Jul 2017 21:44 #95556
And you have "enable_raw" in you config string?
09 Jul 2017 22:10 #95557
I have this in my hal;
loadrt hm2_eth board_ip="10.10.10.10" config="firmware=hm2/7i96/7i96.BIT num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx enable_raw"
I've attached my hal file as well
09 Jul 2017 22:33 #95558
OK a couple things funny in the hal file:
firmware=hm2/7i96/7i96.BIT and sserial_port_0=00xxxx should be removed from the config line
but the actual problem is likely this:
setp hm2_7i96.0.watchdog.timeout_ns 1000000
You have set the watchdog timeout to the servo period (assuming default 1 ms servo thread period)
This pretty much guarantees that it will timeout and disable all outputs
This should be set for at least 10 ms (10000000 ns)
09 Jul 2017 23:23 #95562
Well all be, it works now. you are the man. Now how about my m101 m102 idea. Is that possible?
09 Jul 2017 23:24 #95563
Replied by andypugh on topic Mesa 7i96 Ethernet board
Yes. M101 etc can call a bash script that uses "halcmd setp" commands
09 Jul 2017 23:37 #95564
Would you happen to know or can tell me where to look for the individual addresses to turn each one on a off?
09 Jul 2017 23:51 #95565
I thought it would be here, but it appears not:
github.com/LinuxCNC/hostmot2-firmware/blob/master/src/regmap
It might be in the same file downloaded direct from Mesa.
10 Jul 2017 00:49 #95569
The output bits are all at the same address, data bits 0..5 are outputs 0..5
to control these as individual bits you would need to use the weighted_sum component
Time to create page: 0.219 seconds
