Mesa 7i96 Ethernet board
20 Jul 2017 22:12 #96185
Replied by andypugh on topic Mesa 7i96 Ethernet board
Changing in to out won't change anything, it will just be more correct.
And if you only changed it in the equation, then the module probably won't even compile.
But the main thing that needs to be done is to fix the equation with the extra brackets.
- microsprintbuilder
- Thank you received: 4
20 Jul 2017 22:58 #96187
by microsprintbuilder
Replied by microsprintbuilder on topic Mesa 7i96 Ethernet board
I changed the equation and it appears that the data is correct. however I only have 2 pins connected so it's completely confirmed. still nothing from the board. I'm going to switch the strobe next.
20 Jul 2017 23:21 #96188
Just noticed the red light is on on the board it doesn't appear to be communicating. changed to my old file it works fine. i changed the strobes 0 & 1 back and forth with no change.
20 Jul 2017 23:43 #96189
so I have found that i lose communication when I change the servo-period below 500000 but I can't get a strobe wave unless i"m below 450000.
20 Jul 2017 23:44 #96190
Replied by PCW on topic Mesa 7i96 Ethernet board
If you have a red light in the 7I96, its most likely that the watchdog has bitten (due to bad latency on the host)
No outputs will work after this happens
The following user(s) said Thank You: snugglylovemuffin
20 Jul 2017 23:52 #96191
I would not set the servo period shorter than 1 ms (1000000)
It may be that the strobe needs to be set every other cycle
(Thats what i did in my script test --> wire strobe to a siggen clock at 500 Hz (every other cycle at 1 KHz servo thread))
21 Jul 2017 00:03 #96193
That doesn't make any sense.
21 Jul 2017 00:18 #96194
So would you wire strobe to a siggen clock?
21 Jul 2017 00:25 #96195
LOL, I don't get it either. I put your setup file and the data strobe file in a m100 ,m101,m105 command and they work pretty good. every once and a while they will shut off. I figured it's a latency problem. I'll try to get the machine computer running tomorrow and see what happens. Thanks for helping me through this.
21 Jul 2017 00:25 #96196
OK, here is a version of the .comp to do that. You can setp the wait parameter to choose the strobe frequency.
component raw_writer "Example for 7i96 AC outputs";
pin in bit out-# [6] "The input data to be written";
pin out unsigned address "Connect to raw.write_address";
pin out unsigned data "Connect to raw.write_data";
pin out bit strobe "Connect to raw.write_strobe";
param r unsigned state=0 "State machine state";
param rw unsigned wait = 4 "how long to wait between strobes";
function _;
license "GPL";
static int ret; // where to go after pause
static int timer;
FUNCTION(_){
switch (state){
case 0: // begin init
address = 0x7e00;
data = 0x1030; //enable AC out, set frequency to 2 MHz
state = 100;
ret = 2;
break;
case 2:
address = 0x1100;
data = 0x1f800;
state = 100;
ret = 4;
break;
case 4:
address = 0x1200;
data = 0x1f800;
state = 100;
ret = 6;
break;
case 6:
address = 0x1104;
data = 0x103ff;
state = 100;
ret = 8;
break;
case 8:
address = 0x1204;
data = 0x103ff;
state = 100;
ret = 10;
break;
case 10: // setup copmplete, now just keep sending pin status
address = 0x7d00;
data = out(0) + (out(1)<<1) + (out(2)<<2)
+ (out(3)<<3) + (out(4)<<4) + (out(5)<<5);
state = 100;
ret = 10;
break;
case 100: // start timer
timer = 0;
strobe = 0;
state = 101;
break;
case 101:
if (timer++ > wait){
strobe = 1;
state = ret;
break;
Time to create page: 0.361 seconds
