How to wire up step/dir
22 May 2020 12:12 #168575
by tecno
Replied by tecno on topic How to wire up step/dir
Sorry but the A-Axis is still on the project shelf ½ way done.
- derekmccoy
22 May 2020 17:59 - 22 May 2020 18:00 #168592
by derekmccoy
Replied by derekmccoy on topic How to wire up step/dir
Ok, Im just asking because I have managed to find out how to set these drives up for step/dir. Unfortunately, you need the Sanyo Denki handheld remote operator and plug it into the drive to make the changes but it is possible.
The manual mentions on page 7-58 how to change it to position mode and page 7-43 how to change it to step/dir (Sanyo calls it 'code + pulse train')
s3.amazonaws.com/Icarus/DOCUMENTS/SanyoDenki_Manuals_2000.pdf
In any case, I was asking why you'd want them in step/dir mode in the first place if it's possible to run the drives in analog using the 7i77
Last edit: 22 May 2020 18:00 by derekmccoy.
22 May 2020 18:23 #168597
by tecno
Easier in S/D mode as X/Y/Z are S/D. I do not have 7i77 only 7i76e + 7i85s
- derekmccoy
22 May 2020 19:02 #168600
by derekmccoy
Fair enough. I'm interested to see you getting this PY2 amp going. Update here when you get back to it.
22 May 2020 19:23 #168601
by tecno
Will do so when I get my thumb out of ..........
Time to create page: 0.090 seconds
