How to wire up step/dir
17 Jun 2017 10:06 #94639
by tecno
How to wire up step/dir was created by tecno
- Thank you received: 1370
17 Jun 2017 11:34 #94642
Replied by Todd Zuercher on topic How to wire up step/dir
Seems obvious,
TB2-2 -> pin 2
TB2-3 -> pin 4
TB2-4 -> pin 1
TB2-5 -> pin 3
Before when you were using Mach3 you only had single ended outputs from a parallel port breakout. That is why you used the 5v to one of the pin pairs.
TB2-2 -> pin 2
TB2-3 -> pin 4
TB2-4 -> pin 1
TB2-5 -> pin 3
The following user(s) said Thank You: tecno
17 Jun 2017 12:12 #94643
by tecno
Replied by tecno on topic How to wire up step/dir
Never had anything else = single ended. Better to ask
25 Jun 2017 18:38 #94936
by tecno
25 Jun 2017 19:17 #94941
Replied by PCW on topic How to wire up step/dir
probably something like:
TB2-2 -> pin 5
TB2-3 -> pin 6
TB2-4 -> pin 7
TB2-5 -> pin 8
Though this is just guessing that drive pins 5 and 6 are step and 7,8 are direction
when the drive is in step/dir mode. If the drive does not have a step/dir mode
the 7I76E stepgen for the drive can be set in CW/CCW mode
Also you probably would not want these connected to stepgen-0
if this is an A axis that would normally be mapped to stepgen-3
This mapping of stepgens/axis is arbitrary, but random assignments tend
to lead to harder to understand hal files
TB2-2 -> pin 5
TB2-3 -> pin 6
TB2-4 -> pin 7
TB2-5 -> pin 8
25 Jun 2017 19:27 #94943
by tecno
Not sure but it could very well be CW/CCW, hard for me to understand all different wording used from different manufacturers. The complete manual pdf file is too big to include here on the forum.
26 Jun 2017 09:44 #94969
by tecno
Is it better to convert step dir to CW/CCW via a board like this?
www.electronics-lab.com/project/stepdir-...ion-control-systems/
26 Jun 2017 11:38 #94979
There is no need for any conversion. The Mesa card can output that type of signal (and some others) directly. The type of stepgen signal is configured via a hal pin. The exact name of the pin will be determined by the Mesa board you are using, but it will end with step_type. Use a setp line in your hal file to set it to one of 0 = Step/Dir, 1 = Up/Down (aka.CW/CCW), or 2 = Quadrature.
- derekmccoy
21 May 2020 20:22 - 21 May 2020 20:27 #168525
by derekmccoy
Hi there, did you ever get these Sanyo Denki PY2 servos going?
Replied by derekmccoy on topic How to wire up step/dir
Last edit: 21 May 2020 20:27 by derekmccoy.
- Thank you received: 5983
21 May 2020 20:33 #168528
Replied by tommylight on topic How to wire up step/dir
There is no need for that board if using Linuxcnc as it can output several types of steps ,
forum.linuxcnc.org/16-stepconf-wizard/39...ration-for-mdrive-17
Time to create page: 0.420 seconds
