5i23 7i49 7i52 8i20
- clematites93
21 Jul 2017 17:41 #96234
by clematites93
Yes it's the shots of scope when the shaft is moving back and forth.
No the bit was not set.
Replied by clematites93 on topic 5i23 7i49 7i52 8i20
On you HALScope screen shots is the shaft moving back and forth?
If not, something very basic is wrong
is the resolver error bit set?
- clematites93
21 Jul 2017 17:44 #96235
by clematites93
Do you think that the firmware is the right one to pilot a 5i23 with a 7i49 and a 7i52 (rmsvss6_8.bit) ?
22 Jul 2017 02:50 #96256
Replied by PCW on topic 5i23 7i49 7i52 8i20
rmsvss6_8 is for a 7I49 and a 7I44
The following user(s) said Thank You: clematites93
- clematites93
22 Jul 2017 20:05 - 22 Jul 2017 20:06 #96291
by clematites93
If not what would the right chain for my needs.
Is there a firmware that allows to connect the resolver's signals (through the 7i49) and to the 7i52 to drive the 8i20?rmsvss6_8 is for a 7I49 and a 7I44
Last edit: 22 Jul 2017 20:06 by clematites93.
23 Jul 2017 13:49 #96314
I'll make up a 7I49+7I52 bitfile on Monday
- clematites93
23 Jul 2017 19:21 #96317
by clematites93
In advance,thank you very much for your 5i23, 7i49 + 7i52 bitfile;
24 Jul 2017 17:11 #96358
The following user(s) said Thank You: andypugh
- clematites93
25 Jul 2017 18:42 #96406
by clematites93
Thank you for your work but question (of beginner) : unlike other files, (svss6_6s.bit or rmsvss6_8.bit), I could not transfer the file : top9054hostmot2.bit to the directory 5i23
freeby.mesanet.com/5i23_7i49_7i52.zip
7I49 on I/O 0..23 7I52 on I/O 24..47
25 Jul 2017 18:52 #96408
Sorry I forgot to rename the file.
Just rename it to something like 5i23_7i49_7i52.bit and copy it to the /lib/firmware/hostmot2/5i23 directory ( you need to use sudo to do the copy )
- clematites93
31 Jul 2017 19:11 #96785
by clematites93
Again thanks to PCW for his advice.
Otherwise, is there a program, which I could draw inspiration from, to allow the use of 7i49 +7i52 together ?
Thanks in advance
Thanks in advance
Time to create page: 0.607 seconds
