5i23 7i49 7i52 8i20
- clematites93
02 Aug 2017 19:53 #96935
by clematites93
Replied by clematites93 on topic 5i23 7i49 7i52 8i20
"7I49 on I/O 0..23 7I52 on I/O 24..47"
concerning the 5i23_7i49_7i52.bit firmware :
At the beginning, before the list of pins, dmesg tells me :.... sserial firmware 43 ....
Then, I can see the pins corresponding to the 7i49 (resolver and other....) I/O 0.... 23 ---> connector P2
but for the 7i52, I/O --> 24....47 I see only hm2_5i23.gpio.0xx.. . (no optical encoder or other)
Question please : In the hal, when calling the firmware, must it add an extra detail other than num_encoder = xx ?
(in another configuration 7i43 + 7i52 + 8i20 + special firmware (thanks PCW) , the 7i52 works very well
02 Aug 2017 23:11 #96952
Replied by PCW on topic 5i23 7i49 7i52 8i20
No, num_encoder should work (and if left out you should get all encoders)
Just tested the bitfile and it works for me, here's the result of the readhmid command:
The following user(s) said Thank You: clematites93
- clematites93
03 Aug 2017 20:34 #96987
by clematites93
for my test with the 5i23, I had not connected the 7i52 to one (or two) 8i20 --> so " sserial and others " inactive. I think my problem comes from the.
Can you confirm it to me before trying to establish hal connections with the 8i20 ?
- clematites93
19 Aug 2017 18:23 #97751
by clematites93
hi,
after many tests, I finally found my error : on the second computer connected to the 5i23 I had left the old firmware.....
Now the 8i20 communicates with the 5i23 via the 7i52. Thanks again to PCW for the new firmware.
I now have to establish many connections hal.
I would like to ask you some more questions on his subject
Time to create page: 0.168 seconds
