follow up: universal driver for raspberry and arduino -
21 Feb 2019 18:36 #126869
by wicki
follow up: universal driver for raspberry and arduino - was created by wicki
hi all,
started from this tread, I now have a working raspberry-driver, which turns the
raspberry-PI into a ethernet-connected multi-IO-interface:
forum.linuxcnc.org/27-driver-boards/3581...r-help-needed#123766
last days, I made some tests with an arduino (with eth-shield) instead of the raspberry. the latency-times are more or less 1ms.
not really amazing, but there may be configurations, where this is more than enough....
what do you think?
does this make sense ?
wicki
what do you think?
wicki
21 Feb 2019 19:02 #126870
Replied by PCW on topic follow up: universal driver for raspberry and arduino -
If it can reliably support a 2 ms servo thread, thats probably adequate for many applications
22 Feb 2019 18:29 #126930
by wicki
Replied by wicki on topic follow up: universal driver for raspberry and arduino -
OK, here is something to play with:
erste.de/ethraw/
10 output-pins
and
8 input-pins
of an arduino-uno.
the component driver ethraw builds:
11 bit OUT TRUE ethraw.0.pin-00-in
11 bit IN FALSE ethraw.0.pin-00-out
11 bit OUT FALSE ethraw.0.pin-15-in
11 bit IN FALSE ethraw.0.pin-15-out
(only 10 OUT and 8 IN as usable with this hardware.
a "mega 2560" will give you a lot more pins.)
have fun
feedback would be fine....
erste.de/ethraw/
10 output-pins
and
8 input-pins
of an arduino-uno.
have fun
10 Jan 2022 16:06 - 06 Feb 2022 11:48 #231314
by virencq
Replied by virencq on topic follow up: universal driver for raspberry and arduino -
Dear wicki,
I am not being able to compile error for arduino uno.
error global variable.
Last edit: 06 Feb 2022 11:48 by virencq.
10 Jan 2022 16:22 #231317
by virencq
// the setup runs once when you press reset
void setup() {
W5100.init();
W5100.writeSnMR(s, SnMR::MACRAW);
W5100.execCmdSn(s, Sock_OPEN);
// first byte in IN packet
pinMode(0, INPUT_PULLUP); // this is an output-pin
pinMode(1, INPUT_PULLUP); // this is an output-pin
pinMode(2, INPUT_PULLUP; // this is an output-pin
pinMode(3, INPUT_PULLUP); // this is an output-pin
pinMode(4, INPUT_PULLUP); // this is an output-pin
pinMode(5, INPUT_PULLUP); // this is an output-pin
pinMode(6, INPUT_PULLUP); // this is an output-pin
pinMode(7, INPUT_PULLUP); // this is an output-pin
// second byte in IN packet
pinMode(8, INPUT_PULLUP); // this is an output-pin
pinMode(9, INPUT_PULLUP); // this is an output-pin
//pinMode(10,INPUT_PULLUP); // this is an output-pin
// first byte in OUT packet
pinMode(A0, INPUT_PULLUP); // set pull-up on analog pin 0
pinMode(A1, INPUT_PULLUP); // set pull-up on analog pin 1
pinMode(A2, INPUT_PULLUP); // set pull-up on analog pin 2
pinMode(A3, INPUT_PULLUP); // set pull-up on analog pin 3
pinMode(A4, INPUT_PULLUP); // set pull-up on analog pin 4
pinMode(A5, INPUT_PULLUP); // set pull-up on analog pin 5
pinMode(A6, INPUT_PULLUP); // set pull-up on analog pin 6
pinMode(A7, INPUT_PULLUP); // set pull-up on analog pin 7
// put MAC-addresses into send-buffer
for (int i=0; i<6; i++) sbuf =radr ;
for (int i=0; i<6; i++) sbuf[i+6]=myadr;
void setup() {
W5100.init();
