7c80 install on rpi 4
21 Apr 2023 16:33 #269567
Replied by PCW on topic 7c80 install on rpi 4
If you cannot control GPIO bit 20, that is GPIO input 20 does not change with GPIO 20 output state, that suggests that possibly the watchdog has bit or you are not looking at the real time
representations of these pins.
Note: you should use the watch tab of halshow while running LinuxCNC to check these
- chernogorsky
21 Apr 2023 16:54 #269569
by chernogorsky
Replied by chernogorsky on topic 7c80 install on rpi 4
Will check that also (i was not aware of whatchdog importance)
But I found the issue
it was: TB5 connector itself, some pins has flapping contacts with the wire (and probably the real output), so I did not see the real output
once I replace it with a another one - all goes as expected
Thank you for help, without it I probably reassmeble and recreate whole wiring befor I found it )
14 Mar 2024 09:54 - 14 Mar 2024 10:59 #295884
by shepherps
Replied by shepherps on topic 7c80 install on rpi 4
Hey All,
I've got a 7c80 on rpi4 using image www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz
sudo mesaflash --device 7c80 --addr /dev/spidev0.0 --spi --readhmid
open: No such file or directory
No 7C80 board found
other users have found running raspi-config works to enable SPI, being Debian 12 that's not an option.
using short ribbon cable, yellow led is on.
Any thoughts?
EDIT
For those looking for a solution, uncomment "dtparam=spi=on" in the config.txt file in in the boot/broadcom folder. Should have thought of this before!
No 7C80 board found
Any thoughts?
EDIT
Last edit: 14 Mar 2024 10:59 by shepherps. Reason: Found solution
Time to create page: 0.119 seconds
