7c80 install on rpi 4
14 Dec 2020 01:59 #191932
Replied by PCW on topic 7c80 install on rpi 4
man hostmot2
and
halcmd show all hm2
and
halcmd show all hm2
The following user(s) said Thank You: rdtsc
28 Jul 2021 15:38 #216128
by Borsti
Replied by Borsti on topic 7c80 install on rpi 4
Hi there,
I decided to open the older post in favor of creating a new one on the same topic as 7C80 & RPI4 as the info is scare for that kind of configuration.
I'm retro-fitting currently a small table carving machine and decided to use RPI4 along with 7C80 due to space, but I'm running into issues with the configuration of PNCCONF as the board is not available and I have no idea how to do it, so I followed the previous posts from jimhurlburt and used the 7i76 as template, but how should I change the *.hal to reflect the I/O?
I understood that the syntax for:
- Input is: hm2_7c80.0.inmux.00.input-00
hm2_7c80.0.inmux.00.input-00-not - Analog should be for Output the syntax - hm2_7c80.0.inmux.00.output-00 ?
- How about the spindle output?
28 Jul 2021 16:24 #216131
Spindle analog is controlled by PWMgen 0
The isolated outputs are SSRs (same hal names as 7I96)
Spindle ENA/FWD is GPIO20, Spindle DIR/REV is GPIO21
Both active low.
halcmd show pin hm2 will show all the hardware pins
halcmd show param hm2 will show all the hardware parameters
Both active low.
28 Jul 2021 16:49 #216136
by Borsti
Thanks for the quick replay - I will check and post later as I have some other task open from my day job
- jimhurlburt
- Thank you received: 3
29 Jul 2021 17:33 #216243
by jimhurlburt
Replied by jimhurlburt on topic 7c80 install on rpi 4
Sir:
Sorry for the delay, I saw the post, wasn't convenient to deal with it right then, then forgot later
Attached are my HAL and ini files. The ini file is specific to my hardware, but may give you something useful to work with. The hal file is what I am using to run my machine. At the moment I don't have a controlable spindle, but the movement works well.
I do have two parallel steppers running the y axis, so you may need to adjust that bit.
If you have questions I will try to take note and monitor this thread for a few days.
Jim
Jim
29 Jul 2021 18:17 - 21 Jan 2022 23:32 #216247
This should be close to a working spindle section of a 7C80 hal file:
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm-abs => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
# ---PWM Generator signals/setup---
setp [HMOT](CARD0).pwmgen.00.output-type 1
setp [HMOT](CARD0).pwmgen.00.scale [SPINDLE_0]OUTPUT_SCALE
setp [HMOT](CARD0).pwmgen.pwm_frequency 5000
setp [HMOT](CARD0).pwmgen.00.out0.invert_output true
# --- Setup 7C80 GPIO bits for FWD/REV spindle control
setp [HMOT](CARD0).gpio.020.invert_output true
setp [HMOT](CARD0).gpio.020.is_output true
setp [HMOT](CARD0).gpio.021.invert_output true
setp [HMOT](CARD0).gpio.021.is_output true
net spindle-cw => [HMOT](CARD0).gpio.020.out
net spindle-ccw => [HMOT](CARD0).gpio.021.out
net spindle-output => [HMOT](CARD0).pwmgen.00.value
net spindle-enable => [HMOT](CARD0).pwmgen.00.enable
setp [HMOT](CARD0).encoder.00.counter-mode 0
setp [HMOT](CARD0).encoder.00.filter 1
setp [HMOT](CARD0).encoder.00.index-invert 0
setp [HMOT](CARD0).encoder.00.index-mask 0
setp [HMOT](CARD0).encoder.00.index-mask-invert 0
setp [HMOT](CARD0).encoder.00.scale [SPINDLE_0]ENCODER_SCALE
net spindle-revs <= [HMOT](CARD0).encoder.00.position
net spindle-vel-fb-rps <= [HMOT](CARD0).encoder.00.velocity
net spindle-vel-fb-rpm <= [HMOT](CARD0).encoder.00.velocity-rpm
net spindle-index-enable <=> [HMOT](CARD0).encoder.00.index-enable
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
And the INI file spindle boilerplate:
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 2000.0
ENCODER_SCALE = 1024.0
OUTPUT_SCALE = 2000
OUTPUT_MIN_LIMIT = -2000
OUTPUT_MAX_LIMIT = 2000
# SPINDLE
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 2000.0
OUTPUT_SCALE = 2000
Last edit: 21 Jan 2022 23:32 by PCW. Reason: missing PWM setup parameters and ABS for spindle speed
13 Aug 2021 18:37 #217698
by Borsti
Hi there
Thanks a lot for the many valuable replays and finally after some days of testing my machine is homing !!!!!
Well, I need now to make sure the spindle runs and the E-Stops working etc..
I still would need some hint in regards to the outputs
# --- MACHINE-IS-ENABLED ---
net machine-is-enabled => hm2_7c80.0.led.CR01 => hm2_7c80.0.gpio.012.out
This one is switching the LED and in HAL-Monitor as well the output but physically I don't have anything in Output 0
... or I just lost myself ?
Thanks for some hints!
13 Aug 2021 19:01 #217699
The outputs on the 7C80 are SSRs:
net machine-is-enabled => hm2_7c80.0.ssr.00.out-00
gpio12 is a sserial expansion port on a 7C80
Do not set it to output mode or you will create a bus
conflict
conflict
14 Aug 2021 05:02 #217732
by Borsti
Thanks PCW !
Looks like I oversaw that and took the logic going backwards from the spindle outputs - but now looks like success!
16 Aug 2021 04:04 #217856
by Borsti
Hi PCW,
I played today with the spindle configuration as you proposed in the post, but the 7c80 is missing the pwm output in my "as received " condition
unless there is a different flash for the card?
Time to create page: 0.151 seconds
