7i95 - How to finish?
28 Jun 2021 03:36 #213087
by JackW327
7i95 - How to finish? was created by JackW327
I'm not sure what to do to finish this 7i95 config. I can ping it. Mesaflash talks to it. It's at 10.10.10.10 and I don't need to change it.
I've got the current 2.9 dev version installed of Linuxcnc. I ran Pncconf and selected the 7i96. Then I went into the [my-machine].hal file and just did a search & replace for 7i96 for 7i95 as a start. I then ran Linuxcnc from the desktop icon created by Pncconf. It works I guess. The watchdog LED on the board turns off. I appear to have packet traffic by the LED on the RJ45. I assume at this time the ports are wrong.
I see the instructions to make something in one of the threads, here . I may have missed it but I'm not sure what that is? Is this still current advice? Is it a hostmot2 for the 7i95? Something else? I assume it's not Linuxcnc itself.
Really, really, sorry.I think what throws me off about this entire process is that everything is all over the place. It's very difficult to get a view of what needs to be done in a direct A to B manner. I don't usually have so much trouble with these things, but, here I am.
- BeagleBrainz
- User is blocked
- Thank you received: 570
28 Jun 2021 04:03 #213089
by BeagleBrainz
Replied by BeagleBrainz on topic 7i95 - How to finish?
Once you install Linuxcnc all the drivers are there for the Mesa cards.
Pcnconf will load all the modules you require.
Sometimes some fine tuning is required, but mostly things “just work”.
If you start your Linuxcnc config and doesn’t exit due to an error the config is good.
All that should be required is to hook up your stepper/servo drivers, and any other hardware and off you go.
What do you mean by “finish your config” ?
Apart from how the steppers connect there are that many variations that it’s hard to have an A to B reference. Some users have limit and home switches, some don’t. Some have spindle control and some don’t and there is a ton of ways to hook a spindle up. Some users hook up a pendant and this can go many many ways.
Then there’s Estop switches, switches you can hook up to work with the GUI.
And there is also several guis you can use.
So what is your end game ?
Just do one bit at a time, say add your external estop, then decide what to do next.
Keep backups of your Hal & ini files just in case things go pear shaped.
If need be comment the files so you know what you were thinking 6 months later.
Another problem we have is many ask questions, but very few do a write up after having got their answers. The community needs help, especially from those that having a first go. That way we all benefit.
28 Jun 2021 05:08 #213090
by JackW327
Replied by JackW327 on topic 7i95 - How to finish?
I don't actually know what I mean by 'finish the config" unfortunately. There are several loose ends that don't seem to be tied off.
The 7i95 does not show up in Pncconf so this is all a hack. I do see code addressing it under hostmot2 on github.
Was the .hal file all I had to tweak? (BTW Linuxcnc did error out before I did that)
Then there is / was a good bit of advice in the thread I referenced above I don't understand very well. The mesa files referenced at one point in the thread are not there anymore ...
I really don't know what config files are used and/or where they all are. So it's hard for me to know what to check.
Well, I guess this week I'll hook up a gecko, a test motor & encoder & see what breaks.
Any advice would be helpful. Happy to post back what I've done here once I get there.
- BeagleBrainz
- User is blocked
28 Jun 2021 07:48 - 28 Jun 2021 08:02 #213099
by BeagleBrainz
your config files are
/home/yourusername/linuxcnc/configs/nameofyourconfig/
If YOU don't know what you mean by your question, it's one that is going to be hard to answer.
You're on the 2.9 (master) branch so you should be good to go (if you installed this via the package manager there shouldn't be any need to build from source).
Ok let's address the errors you got first before going any further.
Can you start up Linuxcnc with your config and when you get your error please read the error log, you may not understand too much, but it does give instructions on where to go next.
Reading the docs, yes reading the docs, is a good start.
If you don't understand advice how can you conclude that it is good advice, good advice is advice you understand.
If you don't understand something start asking a question about something specific you don't understand. Unless we know what you don't understand it's really really hard to help.
Last edit: 28 Jun 2021 08:02 by BeagleBrainz.
29 Jun 2021 01:59 - 29 Jun 2021 02:04 #213204
by JackW327
Just trying to be honest and open with everyone about where I'm at. I could fake it but that does not help anyone. I do appreciate the tips.
I may have answered my own question. I captured the below from the CLI startup. This looks like Linuxcnc is talking to the board and loading the correct config. I checked the pins reported with the manual and they seem to match. TB6 is not there, but, I think I would need to define some inputs for that to show up.
Is it a reasonable conclusion that this means I'm probably good to go?
CLI Input:
Output:
In ~/linuxcnc/configs/Rosie-01.pncconf there are loads of lines for pins. They don't seem to match the 7i95 board. They might match a 7i96. I am assuming if the board can be queried that the result over rides this file. Anyone know if that's correct?
I'll see what I can do from here.
Best,
CLI Input:
linuxcnc /home/jdelaney/linuxcnc/configs/Rosie-01/Rosie-01.ini
Output:
LINUXCNC - 2.9.0-pre0-4068-gdd36475ed
Machine configuration directory is '/home/jdelaney/linuxcnc/configs/Rosie-01'
Machine configuration file is 'Rosie-01.ini'
Starting LinuxCNC...
Found file(REL): ./Rosie-01.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:15:00:73
hm2_eth: discovered 7I95
hm2/hm2_7i95.0: Low Level init 0.15
hm2/hm2_7i95.0: Smart Serial Firmware Version 43
hm2/hm2_7i95.0: 58 I/O Pins used:
hm2/hm2_7i95.0: IO Pin 000 (TB3-02/TB3-03): StepGen #0, pin Step (Output)
hm2/hm2_7i95.0: IO Pin 001 (TB3-04/TB3-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i95.0: IO Pin 002 (TB3-08/TB3-09): StepGen #1, pin Step (Output)
hm2/hm2_7i95.0: IO Pin 003 (TB3-10/TB3-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i95.0: IO Pin 004 (TB3-14/TB3-15): StepGen #2, pin Step (Output)
hm2/hm2_7i95.0: IO Pin 005 (TB3-16/TB3-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i95.0: IO Pin 006 (TB3-20/TB3-21): StepGen #3, pin Step (Output)
hm2/hm2_7i95.0: IO Pin 007 (TB3-22/TB3-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i95.0: IO Pin 008 (TB4-02/TB4-03): StepGen #4, pin Step (Output)
hm2/hm2_7i95.0: IO Pin 009 (TB4-04/TB4-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i95.0: IO Pin 010 (TB4-08/TB4-09): StepGen #5, pin Step (Output)
hm2/hm2_7i95.0: IO Pin 011 (TB4-10/TB4-11): StepGen #5, pin Direction (Output)
hm2/hm2_7i95.0: IO Pin 012 (TB4-14/TB4-15): IOPort
hm2/hm2_7i95.0: IO Pin 013 (TB4-16/TB4-17): IOPort
hm2/hm2_7i95.0: IO Pin 014 (TB3-16/TB3-17): IOPort
hm2/hm2_7i95.0: IO Pin 015 (TB4-20/TB4-21): IOPort
hm2/hm2_7i95.0: IO Pin 016 (TB4-22/TB4-23): IOPort
hm2/hm2_7i95.0: IO Pin 017 (TB4-22/TB4-23): IOPort
hm2/hm2_7i95.0: IO Pin 018 (TB1-01/TB1-09): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i95.0: IO Pin 019 (TB1-04/TB1-12): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i95.0: IO Pin 020 (TB1-07/TB1-15): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i95.0: IO Pin 021 (TB1-17/TB2-01): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i95.0: IO Pin 022 (TB1-20/TB2-04): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i95.0: IO Pin 023 (TB1-23/TB2-07): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i95.0: IO Pin 024 (TB2-09/TB2-17): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i95.0: IO Pin 025 (TB2-12/TB2-20): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i95.0: IO Pin 026 (TB2-15/TB2-23): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i95.0: IO Pin 027 (Internal EncMux): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i95.0: IO Pin 028 (Internal InMux0): InMux Input Mux #0, pin addr0 (Output)
hm2/hm2_7i95.0: IO Pin 029 (Internal InMux1): InMux Input Mux #0, pin addr1 (Output)
hm2/hm2_7i95.0: IO Pin 030 (Internal InMux2): InMux Input Mux #0, pin addr2 (Output)
hm2/hm2_7i95.0: IO Pin 031 (Internal InMux3): InMux Input Mux #0, pin addr3 (Output)
hm2/hm2_7i95.0: IO Pin 032 (Internal InMux4): InMux Input Mux #0, pin addr4 (Output)
hm2/hm2_7i95.0: IO Pin 033 (Internal InMuxData): InMux Input Mux #0, pin muxdata (Input)
hm2/hm2_7i95.0: IO Pin 034 (TB5-13/TB5-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i95.0: IO Pin 035 (TB5-15/TB5-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i95.0: IO Pin 036 (TB5-17/TB5-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i95.0: IO Pin 037 (TB5-19/TB5-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i95.0: IO Pin 038 (TB5-21/TB5-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i95.0: IO Pin 039 (TB5-23/TB5-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i95.0: IO Pin 040 (internal): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i95.0: IO Pin 041 (P1-01/DB25-01): IOPort
hm2/hm2_7i95.0: IO Pin 042 (P1-02/DB25-14): IOPort
hm2/hm2_7i95.0: IO Pin 043 (P1-03/DB25-02): IOPort
hm2/hm2_7i95.0: IO Pin 044 (P1-04/DB25-15): IOPort
hm2/hm2_7i95.0: IO Pin 045 (P1-05/DB25-03): IOPort
hm2/hm2_7i95.0: IO Pin 046 (P1-06/DB25-16): IOPort
hm2/hm2_7i95.0: IO Pin 047 (P1-07/DB25-04): IOPort
hm2/hm2_7i95.0: IO Pin 048 (P1-08/DB25-17): IOPort
hm2/hm2_7i95.0: IO Pin 049 (P1-09/DB25-05): IOPort
hm2/hm2_7i95.0: IO Pin 050 (P1-11/DB25-06): IOPort
hm2/hm2_7i95.0: IO Pin 051 (P1-13/DB25-07): IOPort
hm2/hm2_7i95.0: IO Pin 052 (P1-15/DB25-08): IOPort
hm2/hm2_7i95.0: IO Pin 053 (P1-17/DB25-09): IOPort
hm2/hm2_7i95.0: IO Pin 054 (P1-19/DB25-10): IOPort
hm2/hm2_7i95.0: IO Pin 055 (P1-21/DB25-11): IOPort
hm2/hm2_7i95.0: IO Pin 056 (P1-23/DB25-12): IOPort
hm2/hm2_7i95.0: IO Pin 057 (P1-25/DB25-13): IOPort
hm2/hm2_7i95.0: registered
Found file(REL): ./custom.hal
note: MAXV max: 1.000 units/sec 60.000 units/min
note: LJOG max: 1.000 units/sec 60.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
note: jog_order='XYZ'
note: jog_invert=set()
Best,
Last edit: 29 Jun 2021 02:04 by JackW327. Reason: Formatting errors
- BeagleBrainz
- User is blocked
29 Jun 2021 02:46 #213205
by BeagleBrainz
The thread you initially referenced, later in the thread has some info regarding the pins.
forum.linuxcnc.org/27-driver-boards/3789...7i95?start=10#151528
If run your config, this assuming you are using axis, you can goto Machine ---> Show HAL Configuration and browse thru the headings on the left to see what pins are available.
The following user(s) said Thank You: JackW327
29 Jun 2021 03:28 - 29 Jun 2021 03:30 #213210
Replied by PCW on topic 7i95 - How to finish?
Once you have created a basic configuration with pncconf (including things like limit/home switches)
you will need to edit the hal file to make a number of changes. pncconf will no longer be useful at this point
so you should setup as much as you can in pncconf before moving to hal file editing.
The 7i95 SSR outputs have the same names as 7I96 SSRs so those should
work as is if you change the card name in the .ini file. The 7I96 uses GPIOs 0..10
for its isolated inputs 0..10. These names need to be changed in the hal file
to work with the 7I95. The 7I95 isolated inputs are named:
hm2_7i95.0.inmux.00.input-00
hm2_7i95.0.inmux.00.input-00-not
through
hm2_7i95.0.inmux.00.input-23
hm2_7i95.0.inmux.00.input-23-not
in a pncconf hal file, these will appear as
[HMOT](CARD0).inmux.00.input-00 etc
Though the names without the substitutions (like hm2_7i95.0.inmux.00.input-23)
will work also
If you want a complete list of hardware pins and parameters, you can issue this command when LinuxCNC is running:
halcmd show all hm2
through
will work also
halcmd show all hm2
Last edit: 29 Jun 2021 03:30 by PCW.
29 Jun 2021 04:08 #213212
by JackW327
Thanks to you both. I think my brain is beginning to get a grip here.
-jd
-jd
25 Sep 2021 01:26 #221527
by JackW327
Thanks y'all. It's been a tough year at work so this has been excruciatingly slow, but, I finally have LinuxCNC talking to the 7i95, the 7i95 talking to the Gecko G320X, and both getting feedback via the ENCY. I just tested it with a spare motor & encoder & a couple of lines of gcode and it appears to be working.
Lot's more to do, but this is a huge step for me!
01 Jan 2022 09:32 #230439
by piflixe
Replied by piflixe on topic 7i95 - How to finish?
dear Jack! I am in a very similar situation to you while trying to set up the 7i95. Only slowly and step by step getting a grip of things but I also think the documentation is very fragmented and there is no step-by-step guide especially for the new mesa cards. I would like to write one when I have something working.
Would you mind sharing the config and hal files with me for reference? Would be really helpful to start of with a configuration that works and see the pin configurations you made.
Thank you and happy new year!
Time to create page: 0.170 seconds
