Closed loop question
- saeed_niknami
22 Nov 2021 21:13 #227326
by saeed_niknami
Closed loop question was created by saeed_niknami
Hello friend
i have a question about mesa card
can mesa card closed loop axis with pwm like we have 3 axis and a spindle mesa card output +/- 10 volt for all axis and spindle and get feed back from drives encoder or axis mounted encoders and make them full close loop for all axes .
if can please give me model of mesa card that can do above opration
By the way spindle is servo spindle has drive and built in encoder
thank you
thank you
22 Nov 2021 22:23 #227331
Replied by PCW on topic Closed loop question
Yes, a Mesa analog servo interface like a 7I77+7I92M or 7I97
can output +-10V for analog servos and accept encoder signals
allowing LinuxCNC to close the position control loop.
- saeed_niknami
22 Nov 2021 22:49 #227333
by saeed_niknami
Replied by saeed_niknami on topic Closed loop question
Sir what is the difference of mesa card close loop with commercial cnc close loop like fanuc haidenhien seimens is there any difference
Thank you
Thank you
23 Nov 2021 00:12 #227348
Replied by andypugh on topic Closed loop question
They are very similar, With one being much cheaper.
- saeed_niknami
23 Nov 2021 12:57 #227400
by saeed_niknami
sir another question
in your opinion which is best for industrial servo driver like delta eston that work with both pulse/dir and analog +/-10
i want to purchase mesa card but i can not make a decision and choose between 7i97 or 7i76..
i want to know mesa close loop is best with step dir or analog pwm.
please help me on this i have three feed axis motor drive with (step/dir or pwm ) and one spindle with pwm .
thank you
thank you
23 Nov 2021 13:08 #227401
I have no experience with it, but I am running some STMBL servo droves that use Mesa smart-serial. (But i can't currently recommend the STMBL boards as they are basically unavailable at this time)
Otherwise, my choice would be governed by which drives I can get at the best price rather than the interface method.
To make the decision harder, have you considered a digital control scheme such as EtherCAT?in your opinion which is best for industrial servo driver like delta eston that work with both pulse/dir and analog +/-10
- saeed_niknami
23 Nov 2021 13:13 #227402
by saeed_niknami
sir i have drives and servo motors all work with both step/dir or pwm very well
my problem is with mesa card . if it does very well on step / dir closed loop i choose 7i76 or if mesa does very well in pwm i will choose 7i97
beside that my spindle only accept pwm +/-10v
thank you
thank you
23 Nov 2021 22:56 #227443
pwm +/-10V would be very unusual. You would generally use one _or_ the other.
(This is not to say that a +/- 10V PWM signal isn't possible, but it isn't a control scheme that I have seen)
Time to create page: 0.322 seconds
