7I96 error
24 Feb 2022 22:31 #235752 by imslo
7I96 error was created by imslo
I finally got my 7I96 board configured and this is the error I get when I try to run it:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.2
Machine configuration directory is '/home/steve/linuxcnc/configs/Ethernet_CNC'
Machine configuration file is 'Ethernet_CNC.ini'
INIFILE=/home/steve/linuxcnc/configs/Ethernet_CNC/Ethernet_CNC.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./Ethernet_CNC.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 192.168.1.121: Resource temporarily unavailable
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./Ethernet_CNC.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./Ethernet_CNC.hal:9: /usr/bin/rtapi_app exited without becoming ready
./Ethernet_CNC.hal:9: insmod for hm2_eth failed, returned -1
1499
Stopping realtime threads
Unloading hal components
Sometimes it will start after a fresh reboot but the start button on axis is inactive.  Can anyone please help me with this?
24 Feb 2022 22:37 - 24 Feb 2022 22:38 #235753 by PCW
Replied by PCW on topic 7I96 error
I would first suggest not using the 192.168.1.121 card address
and instead use 10.10.10.10 (this may not be the issue but it best
to not use an address that may overlap NAT ranges)
If you have intermittent connectivity issues I would check that the 7I96s
5V power does not drop out when under load (check to see if the card
ever resets randomly or when you start LinuxCNC)
Last edit: 24 Feb 2022 22:38 by PCW.
25 Feb 2022 01:59 #235761 by imslo
Replied by imslo on topic 7I96 error
I don't really know how to change the ip. I see ever where to change the jumper and I have done it numerous times. When I change it my pc can't find the device. Do I have to do more than just changing the jumper? I will read up on the what the leds on the card mean. I have a 5v regulator with cap for my power supply to the card.
25 Feb 2022 02:12 - 25 Feb 2022 02:13 #235762 by PCW
You set the address to 10.10.10.10 by setting Jumpers
W5 and W6 to DOWN UP:
W5 W6
D    U
When this is done you must also set the host (PC) address to
say 10.10.10.100
Last edit: 25 Feb 2022 02:13 by PCW.
25 Feb 2022 02:25 #235764 by imslo
Thanks for the reply. I will give it a try.
25 Feb 2022 17:19 #235800 by BigJohnT
Replied by BigJohnT on topic 7I96 error
You might want to install and use my 7i96 Configuration Tool it has quite a bit of info and can test the NIC time.
gnipsel.com/mesa/7i96/install.html
JT
04 Mar 2022 12:20 #236336 by imslo
I finally got everything running except I don't have my probe hooked up, I am running on 21 volts. Should I use 5 volts or 21 volts for the probe. I also have 12 volts available. I think I have seen somewhere to use 21 volts but I want to be sure. I don't want to blow my board up. .
04 Mar 2022 14:09 #236348 by BigJohnT
Terminal block TB3 is are the 7I96s isolated I/O connector. This has 11 3V-24V
inputs and six isolated high current outputs.
From the 7i96 manual...
JT
11 Mar 2022 18:04 #236947 by imslo
What kind of 5 volt power supply should i use for my 7I96? I am using a common 7805 regulator. The board will run a few seconds and a couple of red lights beside the input terminal start blinking and apparently the board has shut down. I get some kind of joint error on linuxcnc. I can cut the power off a little while and turn it back on and the board goes through the same sequence. Nothing but the board is powered by the regulator. I am inputting about 20 volts to the regulator.
11 Mar 2022 18:39 - 11 Mar 2022 18:40 #236949 by BigJohnT
If your speaking of P3
P3 is the 7I96s 5V power connector. Do not supply any voltage other than 5V to P3!
A 5vdc regulated power supply will work. In a pinch you can use USB 5v if you don't have much load on the 5v
JT
Last edit: 11 Mar 2022 18:40 by BigJohnT.
Moderators: PCWjmelson
Time to create page: 0.174 seconds
