7I96 error
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.2
Machine configuration directory is '/home/steve/linuxcnc/configs/Ethernet_CNC'
Machine configuration file is 'Ethernet_CNC.ini'
INIFILE=/home/steve/linuxcnc/configs/Ethernet_CNC/Ethernet_CNC.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./Ethernet_CNC.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 192.168.1.121: Resource temporarily unavailable
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./Ethernet_CNC.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./Ethernet_CNC.hal:9: /usr/bin/rtapi_app exited without becoming ready
./Ethernet_CNC.hal:9: insmod for hm2_eth failed, returned -1
1499
Stopping realtime threads
Unloading hal components
Sometimes it will start after a fresh reboot but the start button on axis is inactive. Can anyone please help me with this?
and instead use 10.10.10.10 (this may not be the issue but it best
to not use an address that may overlap NAT ranges)
If you have intermittent connectivity issues I would check that the 7I96s
5V power does not drop out when under load (check to see if the card
ever resets randomly or when you start LinuxCNC)
W5 and W6 to DOWN UP:
W5 W6
D U
When this is done you must also set the host (PC) address to
say 10.10.10.100
gnipsel.com/mesa/7i96/install.html
JT
Terminal block TB3 is are the 7I96s isolated I/O connector. This has 11 3V-24V
inputs and six isolated high current outputs.
From the 7i96 manual...
JT
P3 is the 7I96s 5V power connector. Do not supply any voltage other than 5V to P3!
A 5vdc regulated power supply will work. In a pinch you can use USB 5v if you don't have much load on the 5v
JT
