- Hardware & Machines
- Driver Boards
- mesaboard 7i76e + 7i85s + 7i85 with ssi for absolute encoder bitfile
17 Mar 2022 15:59 - 17 Mar 2022 16:02 #237535
by nachoalja
Hello everyone.
I 'm new in this forum. It's the first time I write.
My cuestion is:
I have a ssi absolute encoder. I want to probe it in 7i76e rs422. Does it exists a bitfile for this?
I have a 7i76e + 7i85s with relative encoders. I would like to have a bitfile to substitute the smart serial port in both boards for ssi rs422. One in 7i76e and in 7i85s.
Other option is to buy a 7i85.
With this last option I want to know if I can use the absolute encoder with the standard --> 7i76e_7i76x1_7i85x1_7i85sx1D.bit
Thanks in advance.
Nacho
My cuestion is:
Thanks in advance.
Nacho
Last edit: 17 Mar 2022 16:02 by nachoalja. Reason: an error
17 Mar 2022 17:32 #237544
Replied by PCW on topic mesaboard 7i76e + 7i85s + 7i85 with ssi for absolute encoder bitfile
Here is a 7I76E +7I85S configuration with both free sserial ports
replaced with SSI interfaces:
18 Mar 2022 11:03 #237629
by nachoalja
Replied by nachoalja on topic mesaboard 7i76e + 7i85s + 7i85 with ssi for absolute encoder bitfile
Thanks for the bitfile.
I have written with mesaflash.
My encoder is double ended for clock and data. clock+, clock-, data+, data-.
The bitfile has pins only for single ended.
Does it exist a bitfile for double ended? or Do I have a solution for joining both pairs in only one pair?
Does linuxcnc hostmost ssi support double ended?
Thanks a lot.
Thanks a lot.
18 Mar 2022 15:20 #237644
The differential signal processing is done by external circuitry,
that is, on the 7I76E, the differential I/O for the SSI interface uses
the RS-422 interface normally used for SSerisl expansion.
This converts the single ended FPGA signals to differential.
The second SSI interface on the 7I85S also uses the 7I85S's
differential interface hardware so has single ended FPGA pins.
(The FPGA pins themselves are not suited to RS-422 interfaces do to lack of common
mode range and fragility, so there is no point in having differential FPGA pins for this usage)
18 Mar 2022 16:29 #237649
by nachoalja
Thank you for your quick answer.
If I understand well the rs422 protocol is differencial and use 4 wires for signal more vcc and ground, total 6.
So i can connect 7i76e mesaboard and 7i85s mesaboard to encoder.
MESABOARD --> ENCODER
GND --> GND
RS-422 RX+ --> DATA+
RS-422 RX- --> DATA--
RS-422 TX+ --> CLOCK+
RS-422 TX- -->CLOCK-
+5VP -->VCC
Thanks for your help.
GND --> GND
+5VP -->VCC
18 Mar 2022 17:15 #237654
Note that sometimes the polarities need to be changed (by swapping the pins)
18 Mar 2022 18:38 #237662
by nachoalja
I have conected but the numbers of the pins rawcount, etc , do not stop to run.
18 Mar 2022 19:10 #237664
by nachoalja
I have this hal
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=-1 ssi_chan_0=articulacion_4%2babsoluto_4%12e num_pwmgens=0 num_stepgens=5 sserial_port_0=00000000"
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.s,pid.c
addf hm2_7i76e.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.a.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf pid.c.do-pid-calcs servo-thread
addf hm2_7i76e.0.write servo-thread
setp hm2_7i76e.0.dpll.01.timer-us -200
setp hm2_7i76e.0.stepgen.timer-number 1
setp hm2_7i76e.0.encoder.timer-number 1
setp hm2_7i76e.0.encoder.00.scale -200
setp hm2_7i76e.0.encoder.01.scale 200
setp hm2_7i76e.0.encoder.02.scale -200
#setp hm2_7i76e.0.encoder.03.scale 416.05285
#setp hm2_7i76e.0.encoder.04.scale -312.5
setp hm2_7i76e.0.ssi.00.frequency-khz 500
setp hm2_7i76e.0.ssi.00.timer-number 1
setp hm2_7i76e.0.ssi.00.absoluto_4.scale -555.55556
setp hm2_7i76e.0.ssi.00.absoluto_4.counts-per-rev 4096
loadrt hostmot2
18 Mar 2022 19:14 #237665
Did you try inverting the clock and data (I suspect both need to be inverted)
18 Mar 2022 21:38 #237679
by nachoalja
Thanks again. I am not in work place.
The monday I will do all the combination to test.
The (n)b after first % in the format string, I realy do not understand. Can you explain me? Maybe is the first bit to comunicate between máster slave?
- Driver Boards
Time to create page: 0.355 seconds
