- Hardware & Machines
- Driver Boards
- mesaboard 7i76e + 7i85s + 7i85 with ssi for absolute encoder bitfile
18 Mar 2022 22:12 #237685
Replied by PCW on topic mesaboard 7i76e + 7i85s + 7i85 with ssi for absolute encoder bitfile
Yes, that format string specifies 2 bits of data (not sure what it is)
followed by 12 bits of encoder data.
Do you have the encoder data sheet?
19 Mar 2022 11:38 #237707
by nachoalja
Replied by nachoalja on topic mesaboard 7i76e + 7i85s + 7i85 with ssi for absolute encoder bitfile
Hello I pass you the data sheet of encoder and the chip of the encoder.
Thanks.
Thanks.
19 Mar 2022 11:40 - 19 Mar 2022 11:47 #237709
by nachoalja
This is the data sheet of the chip from page 1_12 because the all sheet exceed.
The info for ssi is there.
Thanks again.
Thanks again.
Last edit: 19 Mar 2022 11:47 by nachoalja. Reason: an error
22 Mar 2022 10:25 #238004
by nachoalja
Hello again.
I have done to work the encoder in the 7i85s without problems, but in the 7i76e the encoder do not stop to jump. I have read the pins with a tester and in the 7i85s the clock pairs give me 5 volt I imagine because they are high to begin and the data pins give near 0 volts.
But in the 7i76e the pairs of the clock they are jumping, jingleing, or osclitating between - and + volts, very quick. Maibe is this the problem.
In the hal show, the pins of rawcount are continualy movimg.
I have changed the pairs, a lot of combinations but none of them worked.
Maybe something in the bitfile?
Maybe in future I will buy a 7i85 to combine with 7i76e + 7i85s if I can not do to work the sistem with rs422 of the 7i76e.
Some suggestion?
Thanks a lot.
Some suggestion?
Thanks a lot.
22 Mar 2022 15:37 - 22 Mar 2022 15:44 #238014
Yes, I think there was an error in the bitfile (wrong enable polarity for the RS-485
interface on the 7I76E) so the CLK output is floated. This should be a correct bitfile:
Last edit: 22 Mar 2022 15:44 by PCW.
22 Mar 2022 18:34 #238021
by nachoalja
Hello I have verify the bitfile with mesaflash and give me this result in the terminal.
usuario@debian:~/Descargas/7i76e_7i76x1_7i85sx1_ssid_2022-03-22$ mesaflash --device 7i76e --addr 10.10.10.10 --verify 7i76e_7i76x1_7i85sx1_ssid.bit
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Error at 0x1493BB expected: 0x0 but read: 0x5
Do I have to write this bitfile?
Thanks again.
Checking file... OK
File type: BIT file
Boot sector OK
Thanks again.
22 Mar 2022 18:42 #238022
Yes, its a different (and hopefully fixed) bitfile.
22 Mar 2022 18:56 #238024
by nachoalja
But one question.
The new bitfile when I verify with mesaflash give me an error. The doubt I have is if I can write this bitfile to fpga without problems?
22 Mar 2022 18:59 #238025
I would expect it to get an error if you have not written it yet because
--verify is comparing the old bitfile in the flash chip with the new bitfile
22 Mar 2022 19:00 #238026
by nachoalja
Ok I understand.
Tomorrow I will write the new bitfile.
Thanks a lot.
Thanks a lot.
- Driver Boards
Time to create page: 0.157 seconds
