7i92, can I use "STEP" outputs with no "DIR"?
- Thank you received: 5256
18 Mar 2022 22:23 #237688
Replied by PCW on topic 7i92, can I use "STEP" outputs with no "DIR"?
Yes, if you are not using stepgens 0..3 on P2 for XYZA
you would need to enable 6 stepgens to get a free stepgen on P1
and therefore lose GPIO5 as an input
If you are not using a G540 and its chargepump,
there is likely better firmware for you application
(maybe one of the 5ABOB firmwares would be closer)
- dannym
19 Mar 2022 00:06 #237695
by dannym
Replied by dannym on topic 7i92, can I use "STEP" outputs with no "DIR"?
OK, back to the dumb question- where do I find these pinouts? I don't have this on my Windows PC and I can't find anything to actually download that has the pinout
19 Mar 2022 00:08 #237696
- dannym
20 Mar 2022 21:35 #237854
by dannym
Thanks!
I did get the setup booting with rotary. Now, I'm stuck on homing. I didn't plan to home the A axis at all, one starting position is as good as another. There's no homing switch for it.
I copied most of my setup from other axes, so it's not surprising- it keeps rolling the axis, searching for the home switch which doesn't exist.
I figured I could add a line to see the homing switch net to be equal to 1 all the time, but a regular homing cycle has that backing-off step and that won't play nice with a fake switch input tied to 1. So maybe not.
What's the elegant way handle homing on a system like this?
- Thank you received: 7408
20 Mar 2022 21:47 #237856
Replied by tommylight on topic 7i92, can I use "STEP" outputs with no "DIR"?
- dannym
21 Mar 2022 06:06 #237876
by dannym
No joy. Set all that to zero and it still tries to home the A axis.
21 Mar 2022 07:01 #237879
Upload hal and ini files here.
- dannym
22 Mar 2022 04:50 - 22 Mar 2022 19:05 #237993
by dannym
Enclosed
I did quite a few variations on the ini file. HOME_SEQUENCE = 0, -1, 4...
This is still LinuxCNC 2.7.4 BTW. Upgrading to a new box soon, I don't think this prob is version-specific
Odd note. The normal sequence was Z, Y, then X1/X2.
In all cases, A-axis will start turning after Y. It starts turning A-axis concurrently as X1/X2 homing begins, regardless of what's in HOME_SEQUENCE, which I find odd. Even if I wanted no homing at all, if it DOES start an unwanted home, it should still use the SEQUENCE and it doesn't.
It will keep turning slowly, indefinitely. I hit arrow keys and it says something about can't jog while homing, but this does halt the motion of A-axis and allows jogging. The A-axis is then left unhomed and we can't enter interpreter mode.
Last edit: 22 Mar 2022 19:05 by dannym.
- dannym
23 Mar 2022 16:59 #238117
by dannym
Any ideas? I'm stuck. I've tried doing exactly as described with no luck, and tried every meaningful iteration I can think of.
It's notable that it's fixing itself alongside the X1/X2 axis as if its HOME_SEQUENCE=2 regardless of what the ini fil specifies. It's making me wonder if the prob isn't somewhere else entirely.
X1/X2 is unusual in that it's got two motors, but that shouldn't make any difference.
- Thank you received: 4081
23 Mar 2022 18:09 #238121
Replied by rodw on topic 7i92, can I use "STEP" outputs with no "DIR"?
This is version specific
joint axes X1/X2 needs version 2.8
I suspect your A is reading the setup for a linear axis.
Time to create page: 0.414 seconds
