5i25 w7i76D 5i25 no firmware and no response to install one
24 May 2022 16:26 - 24 May 2022 16:38 #243702
by RobKin
I have verified my jumpers and power requirements on the 7i76. 5i25 w1 up, w2 up, w3 up, w4 up, w5 up. 7i76 w1 left, w2 left, w3 left, w4 right, w5 right, w6 right. Seems like my 5i25 is dead. Purchased these boards a week ago, and my linuxcnc & mesaflash install is from today. Are there supposed to be LEDs on the 5i25 board? I do not see any.
rob@CNC:~$ sudo mesaflash --device 5i25 --readhmid
ERROR: no HOSTMOT2 firmware found. FFFFFFFF
Configuration Name:
BoardName :
FPGA Size: 0 KGates
FPGA Pins: 0
Number of IO Ports: 0
Width of one I/O port: 0
Clock Low frequency: 0.0000 MHz
Clock High frequency: 0.0000 MHz
IDROM Type: 0
Instance Stride 0: 0
Instance Stride 1: 0
Register Stride 0: 0
Register Stride 1: 0
Modules in configuration:
Configuration pin-out:
Try to load the .bit file:
rob@CNC:~$ sudo mesaflash --device 5i25 --write 5i25_7i76x2.bit
Checking file... OK
File type: BIT file
Error: BootSector is invalid
So tried this:
rob@CNC:~$ sudo mesaflash --device 5i25 --fix-boot-block --fallback --write 5i25_fallback.bit
Checking file... OK
File type: BIT file
Erasing sector 0 boot block
BootBlock installed
Failed to write valid boot sector
Nothing seems to be happening, what can I do next?
Configuration Name:
BoardName :
FPGA Size: 0 KGates
FPGA Pins: 0
IDROM Type: 0
Checking file... OK
File type: BIT file
So tried this:
Checking file... OK
File type: BIT file
BootBlock installed
Last edit: 24 May 2022 16:38 by RobKin. Reason: added jumper settings
24 May 2022 16:36 #243703
Replied by PCW on topic 5i25 w7i76D 5i25 no firmware and no response to install one
Looks like a card access/connectivity issue.
I would try another slot or cleaning the PCI slot on the motherboard.
BTW if you have a card access issue (you cannot get a reasonable
mesaflash --readhmid response), its not a good idea to attempt to
write anything to the cards flash memory as you are likely to corrupt
the configuration image.
24 May 2022 16:51 #243704
by RobKin
Replied by RobKin on topic 5i25 w7i76D 5i25 no firmware and no response to install one
cleaned port, reinstalled card. tried readhmid and says No 5i25 board found.
24 May 2022 16:53 #243705
by RobKin
I assume I have a really expensive paperweight now
24 May 2022 16:59 #243706
OK first I would check if the card is configured.
If you have any solid red LEDs on after power up,
the card failed to configure and must be re-programmed via
JTAG to recover (This can be done by sending the card back to Mesa)
24 May 2022 17:36 #243708
by RobKin
CR3 & CR4 are solid red as soon as computer turns on.
Thanks for the info, Spent a week trying to make this work. May just go back to Mach3
24 May 2022 17:58 #243711
by Clive S
Replied by Clive S on topic 5i25 w7i76D 5i25 no firmware and no response to install one
Stick with it PCW is Mesa, the best service anywhereCR3 & CR4 are solid red as soon as computer turns on.
24 May 2022 18:01 #243712
Yes, if the CPU cannot access the card properly you are going to have all
sorts of issues.
I would suspect the original issue was a dirty or bad PCI slot but it
could also have been a bad/marginal 5I25 so sending it back for
re-programming and retesting is a good idea.
sorts of issues.
Time to create page: 0.229 seconds
