7i97 + 7i76D with Mesa Configuration Tool
- smc.collins
- Thank you received: 109
12 Jun 2022 00:21 #244967
by smc.collins
7i97 + 7i76D with Mesa Configuration Tool was created by smc.collins
I am going to be using a 7i97 with a 7i76D : for the additional IO" with the 25pin db connector from the 7i97 "flat ribon cable breakout" . I have the sample firmware for this as well as the base hal and ini files but the tool refuses both.
www.mesanet.com/software/parallel/7i97.zip
14 Jun 2022 20:11 - 14 Jun 2022 20:15 #245145
by BigJohnT
Replied by BigJohnT on topic 7i97 + 7i76D with Mesa Configuration Tool
You can only open an ini file created with the Mesa Configuration Tool.
I'll have to add that firmware in the morning. Last time I checked there was no firmware for the 7i97...
It will take some time to add a daughter card to an all in one card...
JT
JT
Last edit: 14 Jun 2022 20:15 by BigJohnT.
- smc.collins
15 Jun 2022 01:12 #245155
by smc.collins
Replied by smc.collins on topic 7i97 + 7i76D with Mesa Configuration Tool
ok, I have my hands busy for at least a week. I decided to just gut the entire machine, the wiring was, engineered like the finest Mercedes electrical system
- Thank you received: 5946
15 Jun 2022 02:13 #245156
And yes, their cars use hydraulics for roof folding and pneumatic for air suspension. Old/older ones used air to shut the engine down, VW used air pumps for central locking, etc etc.
Replied by tommylight on topic 7i97 + 7i76D with Mesa Configuration Tool
Having worked a lot on those Mercedes electrical/electronics/hydraulics/pneumatic systems, i would not entirely agree!.... the wiring was, engineered like the finest Mercedes electrical system
- smc.collins
15 Jun 2022 02:37 #245158
by smc.collins
The sarcasm just didn't shine through, Mercedes Benz, the Rubegoldberg of automotive engineering
15 Jun 2022 13:29 #245194
by BigJohnT
You should be able to flash the 7i97, create a configuration for a 7i76 or 7i78 but I didn't have time to test it this morning.
JT
JT
The following user(s) said Thank You: smc.collins
- smc.collins
15 Jun 2022 19:38 #245218
by smc.collins
I will play with this over the weekend, and thanks so much fpr getting nit done so quickly !!!!!!.
You know of any good tutorials on ladder logic ?
16 Jun 2022 11:31 #245253
by BigJohnT
- smc.collins
22 Jun 2022 02:30 #245576
by smc.collins
there's a bug with the 7i97 for configuring the Axes's on the 7i97, you can configure the daughter card, but not the 7i97, which, is weird.
23 Jun 2022 13:17 #245677
by BigJohnT
I'll look into that.
JT
JT
Time to create page: 0.217 seconds
