7i97 + 7i76D with Mesa Configuration Tool
- smc.collins
- Thank you received: 109
23 Jun 2022 21:54 #245729
by smc.collins
Replied by smc.collins on topic 7i97 + 7i76D with Mesa Configuration Tool
it shows card 1 as greyed out, as well as the axis tabs, even when not selecting 7i97, but you can select the 7i76 and configure with no problem.
23 Jun 2022 22:07 #245731
by JT
Replied by JT on topic 7i97 + 7i76D with Mesa Configuration Tool
Can you upload your ini file?
JT
JT
- smc.collins
24 Jun 2022 01:44 #245749
by smc.collins
I didn't get that far, because I wasn't able to create the axese's in question, I read through the supplied read me and help and I think I am using the software properly.
24 Jun 2022 13:05 - 24 Jun 2022 13:33 #245780
by JT
I took a quick look at all in one boards with a daughter card and I have work to do on that. For now you can create a configuration for a 7i97 but not with a daughter card.
Edit: So that looks like the next thing I need to work on an all in one board with a daughter card.
JT
JT
Last edit: 24 Jun 2022 13:33 by JT.
- smc.collins
24 Jun 2022 17:27 - 24 Jun 2022 18:25 #245801
by smc.collins
Ok, I am going to go ahead with just starting my build with the 7i97 and Hopefully when I get to needing the IO of the 7i76 you've got it all worked out. I appreciate the fast response !, where do I send the beer ?
A quick note on spindle, I don't know if you considered the 7i97 only has analog servo outputs, and the spindle needs to be configured as a analog output for outputs 0-5 there is no way to set the spindle for a analog output that I can see. Also I need to be able to use it as a Axis for synchronised motion turning thread features etc, I am still fuzzy on how that is handled.
I see no way to assign the encoder inputs to the various axes
I did peruse the PDF, and I am a bit confused on how to calculate the encoder scales, Is it encoder scale x 4 = base unit, and base unit is inch or millimeter ? or is it the encoder count per/rev x screw pitch
IE
(4096 ppr x 4) X 5tpi = 81,960 etc + pnconf style ?
I wasn't sure on what the base unit was for the math.
IE
Last edit: 24 Jun 2022 18:25 by smc.collins.
24 Jun 2022 20:19 - 24 Jun 2022 20:21 #245807
by JT
Send beer to Swamp East Missouri
Opening the 7i97 manual from the tool I see that Six uncommitted OPTO coupler outputs are available for drive enable. Four of these outputs (ENA0 through ENA3) are switched in common while ENA4 and ENA5 can be independently switched for spindle applications.
So that means either AOUT4 or AOUT5 can be used for a spindle. Looks like I have a bit of work to do for a 7i97 spindle. I'll start on that in the morning with my coffee.
The encoder scale is how many pulses it takes to move one user unit. A user unit is either a millimetre or an inch.
JT
JT
Last edit: 24 Jun 2022 20:21 by JT.
- smc.collins
24 Jun 2022 23:18 #245815
by smc.collins
How do you assign the encode inputs ?
- smc.collins
25 Jun 2022 04:35 #245842
by smc.collins
lmk where to send the beer gift card ! the efforts are greatly appreciated !
26 Jun 2022 13:37 #245922
by JT
JT
Currently the encoder on Joint 0 will be encoder 0 and joint 1 will be encoder 1 etc.How do you assign the encode inputs ?
JT
- smc.collins
26 Jun 2022 13:40 #245923
by smc.collins
that is good know, thanks !
Time to create page: 0.216 seconds
