New project, litehm2: a hostmot2 port to linsn rv901t
- Spacehitchhiker42
26 Mar 2024 10:18 - 26 Mar 2024 10:22 #296802
by Spacehitchhiker42
Replied by Spacehitchhiker42 on topic New project, litehm2: a hostmot2 port to linsn rv901t
Is there any massively insurmountable reason that this project wouldn't work with a Trion T20 FPGA? I did notice that SRAM was mentioned in a previous post, does this require an external SRAM chip or does it use internal FPGA resources?
Last edit: 26 Mar 2024 10:22 by Spacehitchhiker42.
26 Mar 2024 21:32 #296843
Replied by PCW on topic New project, litehm2: a hostmot2 port to linsn rv901t
It should be possible since the HM2 source that supports the T20
is available. I would expect that the on-chip RAM is sufficient
- Spacehitchhiker42
27 Mar 2024 07:48 #296873
I did notice that in litehm2.py there are imports for "M12L64322a" and "GENSDRPHY", though they do not appear to be used anywhere. I just wanted to confirm that they aren't required for functionality.
29 Mar 2024 05:24 #297061
by xu
Replied by xu on topic New project, litehm2: a hostmot2 port to linsn rv901t
How do I use two 901T boards connected to the switch at the same time?
In addition to setting the IP address of the card 10.10.10.10 and 10.10.10.11 , how does the HAL know that it is the only IO pin
29 Mar 2024 19:32 #297135
You load the driver with multiple ip addresses specified
The hal pins/parameters will have different board numbers.
Its also important with multiple cards to use the read-request function
so that the second card does not have wait for the first card to respond
before its read data request is sent.
08 May 2024 13:42 - 08 May 2024 13:43 #300122
by sensille
Replied by sensille on topic New project, litehm2: a hostmot2 port to linsn rv901t
Sorry for the late reply. Yes, the SDRAM is not used, only internal resources (BRAM).
Last edit: 08 May 2024 13:43 by sensille.
08 May 2024 17:34 #300143
by IlyaKw
Replied by IlyaKw on topic New project, litehm2: a hostmot2 port to linsn rv901t
Time to create page: 0.096 seconds
