New project, litehm2: a hostmot2 port to linsn rv901t
  • Platinum Member
  • Platinum Member
14 Mar 2024 03:50 #295873 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic New project, litehm2: a hostmot2 port to linsn rv901t
This may help:
github.com/sensille/litehm2/issues/3
To tell the I never played with the image, just installed the tools natively on my Linux machine.
14 Mar 2024 07:47 #295880 by IlyaKw
Use this command to add path for riscv folder
PATH="/opt/oss-cad-suite/bin:/opt/riscv/bin:$PATH"
14 Mar 2024 12:15 - 14 Mar 2024 12:19 #295894 by xu
Adding PATH="/opt/oss-cad-suite/bin:/opt/riscv/bin:$PATH" still gives the same alarm. The xxx.conf file must be renamed "board.conf" before make can run. The .conf file is renamed using the file you left in configs.
Last edit: 14 Mar 2024 12:19 by xu.
14 Mar 2024 12:23 #295895 by IlyaKw
Add PATH="/opt/oss-cad-suite/bin:/opt/riscv/bin:$PATH" still gives the same alarm. The xxx.conf file must be renamed "board.conf" before make can run.
The config file may have the name whatever you want.
In the attached file clearly noted the reason of the error:
[b]OSError: Unable to find any of the cross compilation toolchains[/b]: - riscv64-pc-linux-musl - riscv64-unknown-elf - riscv64-unknown-linux-gnu - riscv64-elf - riscv64-linux - riscv64-linux-gnu - riscv-sifive-elf - riscv64-none-elf - riscv32-unknown-elf - riscv32-unknown-linux-gnu - riscv32-elf - riscv-none-embed - riscv-none-elf
14 Mar 2024 14:15 #295901 by xu
Thank you. Because the virtual machine cannot access the Internet due to the network card, the Risc-v toolchain cannot be installed.
14 Mar 2024 14:18 #295902 by IlyaKw
It is already installed in /opt/riscv. The $PATH doesn't contain the path to it.
14 Mar 2024 15:00 #295906 by xu
Okay, sir, this is too difficult for me. I used the conf file you wrote and changed it to see if you can help me generate a .bin .bit file. Sorry, I am using a translation software and my expression may not be accurate. Thank you, sir
14 Mar 2024 15:15 - 14 Mar 2024 15:17 #295907 by IlyaKw
Please find attached .bit file based on this config
File Name: litehm2.rar
File Size:188 KB
Last edit: 14 Mar 2024 15:17 by IlyaKw.
15 Mar 2024 01:43 #295930 by xu
Thank you, sir
16 Mar 2024 03:12 #296022 by xu
gentlemen . bit file still cannot be generated
Moderators: PCW, jmelson
